Thread: slingshot shocks
Old 06-22-2009, 11:15 AM   #1
Default slingshot shocks
just got revo shocks for the slingshot, they came with red spring , a little stiff , i know they say to use jato whites but with what stripe on the end of the spring , a part # would be great thanx
LEROY is offline   Reply With Quote
Old 06-22-2009, 11:24 AM   #2
Yellow= .7 front
Orange= .9 front
Tan= 1.0 rear
Green= 1.1 front
Silver= 1.2 rears
Gold= 1.2 fronts
Pink= 1.4 rear
Blue= 1.6 rear
I use yellows up front and greens out back. Oh I also drilled out the pistons using a 1/8" bit and filled them with 10wt oil. They work awsome. You could also just buy a jato shock rebuild kit and use the 3's up front and the 4's out back if you don't want to drill the stock pistons.
bigflex is offline   Reply With Quote
Old 06-22-2009, 11:27 AM   #3
is this going on an axial or an MOA rig? If its for an MOA you might want to go yellow all arround.
Old 06-22-2009, 01:03 PM   #4
i use the yellow .7 all way around....also have 1.4 pistons up front with 1/8" hole bored in it and 1.3 pistons in rear with 1/8" hole bored in it...works well for me so far....
robchas is offline   Reply With Quote
