06-27-2009, 07:48 PM | #1 |
Quarry Creeper Join Date: Oct 2006 Location: Tehachapi
| wobble after DNA dig install
just put in a new DNA dig on my axial. The whole drive train has a wobble now in forward and reverse. Is this common or did i do something wrong. Ill get some video of it in a bit. |
06-27-2009, 07:56 PM | #2 |
Shouldn't have a wobble to it,unless somethings installed wrong or something is bent.
06-27-2009, 08:00 PM | #3 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
If your not careful,when you put the out drives in the final gear it may get it in a bind and not seat right.Check your out drive shaft to the front axle and see if thats running stright.You could have a drive shaft binding,not sliding in far enough too. |
06-27-2009, 09:51 PM | #4 |
here is some video. not sure what it could be. everything lined up good and driveshafts are straight. http://www.youtube.com/watch?v=nerq8pQGHc8 |
06-27-2009, 09:56 PM | #5 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
The drive plate that goes onto the tranny output is not seated right. It needs to be flat & no wobble when you turn the tranny by hand.
06-27-2009, 09:57 PM | #6 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Looks to me that the shaft isnt seated right. Almost like its warped.
06-27-2009, 11:36 PM | #7 |
ok, took it apart, checked everything and put it back together. same BS. http://www.youtube.com/watch?v=mQqIj1-QBoU |
06-28-2009, 12:01 AM | #8 | |
Newbie Join Date: May 2009 Location: US
06-28-2009, 10:29 AM | #9 |
Rock Stacker Join Date: Nov 2008 Location: Yuma
I had one that did that, it ended up being that one of the outputs that have the three little screws on it, one was striped.It would not let the two outputs lay flat against the bottom gear and i got the wobble. Called dna and they took care of it. Hope this helps.
06-28-2009, 11:23 AM | #10 | |
i think your right, i took it apart and it had mooved causing it not to seat right. | |
06-28-2009, 05:28 PM | #11 |
Quarry Creeper Join Date: Oct 2008 Location: Madera
| Any luck "straightening" it out this afternoon? |
06-28-2009, 06:43 PM | #12 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
looks like a warped output gear. Are you running stock plastic gears or metal ones?
06-29-2009, 07:33 AM | #13 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
it looks, like the spool isn't seated all the way on one side...but feel free to shoot an email to customerservice@dna-rc.com and Sol can make sure you are working properly.
06-30-2009, 12:35 AM | #14 |
i am running plastic gears, it just wont seat in there right. it has a little bit of wobble still.
