07-10-2009, 08:23 PM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: nc
| Little Help needed
So I am just getting to putting my rig together and have an issue. Here is my setup. rockshow chassis integy 35 turn crawler motors punk rc dig switch tekin fxr esc castle bec airtronics mx3 modded hot racing moa's problem i am having is when i turn everything on it seems to glitch real bad. I try to throttle forward and its slow glitching and at times it completely is unresponsive. Other times when you put it in reverse its wide open and goes by itself at times. I am not new to the fxr and have the capacitor on it and cut the wire for the internal bec on it. Any guess as to where I may start at? |
07-10-2009, 08:26 PM | #2 |
Hateraide Join Date: Dec 2008 Location: Mission BC
Is you controller set up like your epa's and stuff
07-10-2009, 08:53 PM | #3 |
yes all set up
07-10-2009, 09:10 PM | #4 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
MOA correct? What are you running for a servo, and what's the mod on your MX3? |
07-10-2009, 09:30 PM | #5 |
moa is correct and servo is a hitec 645 and the mod is for the 3rd channel its a 3 position switch front/both/rear
07-10-2009, 09:41 PM | #6 |
Make sure that all of your Tx settings are at neutral and try re-calibrating your FX-R with your Tx and see if that clears it up at all. If you have the Hot Wire for the FX-R get the update from Tekin's site and run it. You can make much finer adjustments with it, and that may help as well. Here's the link to kaetwo's original FX-R thread...you may find it helpful. Kaetwo's Tekin FX-R Review... |
07-11-2009, 09:40 AM | #7 |
got it fixed it was the receiver that was bad changed it out and all good
07-11-2009, 06:39 PM | #8 |
Cool |
