07-15-2009, 10:29 PM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
| best alum. ax10 shocks for droop
I'm using the stock shocks right now and cannot get them to stop leaking! I want to know whats the best aluminum shock to replace them with? I need the same length as the stocks and I know i can build the stocks with aluminum bodies but for $25 for 2 bodies then needing aluminum caps is a rip. Post up what you think. Last edited by TANK; 07-15-2009 at 10:32 PM. |
07-16-2009, 12:28 PM | #2 |
Pebble Pounder Join Date: Oct 2005 Location: Rocklin / Ukiah, CA
Can you run the Losi 4" crawler shocks in a droop setup?
07-16-2009, 12:34 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
traxxas big bores are pretty close to the stock lengths the losi shocks are shorter, but a great choice i run drooped losis on my slingshot and they work good and give me more flex than the revos |
07-16-2009, 12:47 PM | #4 |
Rock Crawler Join Date: Nov 2008 Location: kansas city
i personaly think 130mm is far too much for any shock. droop or standard. i would go to the losi 4" (100mm) i also like the traxxas BB
07-16-2009, 01:27 PM | #5 |
Rock Stacker Join Date: Aug 2008 Location: Spring TX
Iv'e never ran a droop setup but I can tell you the Losi shocks are very nice.
07-16-2009, 07:32 PM | #6 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
I like the Duratrax Evader shocks, they have no shock caps & are fairly cheap. The ones I use are from the 1st gen evader, the evader ext shocks are plastic bodies I believe. They will be a bit shorter than the axials, use the rear evader shocks. here is a link. http://www3.towerhobbies.com/cgi-bin...?&I=LXAMK2&P=7 They also come in purple, and blue anodized, & hard anodized finish. The hard anodized are more $$, they also have Ti nitride shock shafts for them. IMO prob 1 of the best things duratrax makes- |
07-16-2009, 09:32 PM | #7 |
well here is another dilemma. I like the Big bores but they don't have balls on each end. And i like the Losi's but they're threaded and i think they'll look dumb in a droop... Whats the best tips to prevent shocks from leaking also cause i cant figure this *hit out...:? |
07-18-2009, 03:56 AM | #8 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
All my buddy's Losi shocks leak a little my droop setup uses Axial replacment alum. bodies w/alum. caps also and they don't leak. |
