07-22-2009, 11:19 AM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Bakersfield
| Where can I get really long shocks?
Im needing shocks longer than the 110mm shocks that i have found. Somewhere in the range of 120 to 160mm. Not quite for sure on the exact length yet. I would appreciate any help you could offer me. Thanks Nate |
07-22-2009, 11:41 AM | #2 |
look for a savage shock but that might be too long, for a super im guessing?
07-22-2009, 11:52 AM | #3 |
Hateraide Join Date: Dec 2008 Location: Mission BC
07-22-2009, 07:19 PM | #4 |
Well im building the Evolution Warthog chassis and the shock mounts really high on the chassis so I need a longer shock
07-22-2009, 08:17 PM | #5 |
Quarry Creeper Join Date: Jan 2009 Location: Hagerstown
Um your best bet is stock length AX10 Shocks. That chassis is made to use the stock AX10 shocks. It will have the right amount of ground clearance with the stock shocks and the bump stocks put on the inside of the shock body. You can even run 4 inch losi shocks or the new 4 inch Axial shocks. If you run a longer shock it will set up way to high. The shock mounts just look high due to the way the chassis is made. look around at some Warthog builds and you will see what I mean.
07-22-2009, 08:28 PM | #6 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
07-23-2009, 05:14 AM | #7 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
How about some 148mm's? Long enough? http://www.rcplanet.com/Integy_Shock...2919silver.htm |
07-23-2009, 06:00 AM | #8 |
Pebble Pounder Join Date: Jan 2009 Location: Crestview
PM sent
07-23-2009, 08:22 AM | #9 |
Those might be winners! Thanks for the reply man |
07-23-2009, 08:25 AM | #10 |
Yea ive been studying that chassis alot and he is using savage shocks i believe. I would use them but my warthog is only 18 inches long, about 1/10 scale and those shocks look a lil to big around...But thanks !!
07-23-2009, 09:20 AM | #11 |
Quarry Creeper Join Date: Mar 2009 Location: Aztec
rc4wd has really long shocks i have a set in the for sell section they are 5 1/2 in's long.
07-23-2009, 04:48 PM | #12 |
In the forums?
