crawler question I have a rs-10 that i modifyed in every way length width and am waiting for my 80 turn 540 size motors axels modifyed already . The problem is im esc ignorant and dont know what to get that will handle both motors .Is there anyone that knows . I have several books none sell a esc designed for two 80turn 540 motors .The orginal esc is for two 380 70 turn motors is there any way i can use it for a while or will it smoke? thank you for your help |
Well, two 80 turn motors will draw the same current as one 40T motor....so anything that will handle a 40T should work fine. The Castle Creations Sidewinder would work perfectly in your truck. |
Im going to two 80 turn brushed motors not brushless will it work ? |
it can be used for brushed or brushless. for brushed you just dont use the white wire. |
Yes, you should have no problems with two 80T brushed motors and the Sidewinder ESC. Quote:
