08-08-2009, 11:33 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Alliance
| rc4wd electronic.....
hi i was looking at the Big Offroader 2.4Ghz 3-Channel Radio & Receiver on rc4wd and does it have a reverse switch or anything that has to do with reverse? and a another question is whats this Castle Creations CC BEC 10A Switching Regulator like what does it do thanks
08-08-2009, 11:46 PM | #2 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
I will have to say if it didnt have a reverse, it shouldnt be available. goto RC4WD and email them through the contact. mike will reply asap as he mainly works nights. The CCBEC or Common sense BEC or any Xternal BEC's job is to allow you to distribute more even voltage to more than usual componets. Most Internal BEC's in and ESC cant handle more than 2 servos, ect. If your running a steering and DIG servo, its best to get it to make sure you dont glitch from not being able to supply the needed 6V per servo |
08-09-2009, 05:36 AM | #3 |
I wanna be Dave Join Date: Nov 2005 Location: Here
When you say reverse...do you mean a channel reverse or a two position 3rd channel switch? The answer would be yes to both. It has the option to reverse the channel (if it is backwards) and also the 3rd channel is a two position that would work with shifting a nitro tranny to reverse... |
08-09-2009, 10:05 AM | #4 | |
08-09-2009, 02:02 PM | #5 |
08-09-2009, 02:07 PM | #6 |
Im sure there is a reversing switch for the channel to switch forward and reverse progress.
08-09-2009, 05:14 PM | #7 |
08-10-2009, 07:22 PM | #8 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
08-10-2009, 08:39 PM | #9 |
