08-15-2009, 03:56 AM | #1 |
Rock Stacker Join Date: Jun 2009 Location: sweden
| rock force or losi comp crawler ?
out of the box ! witch one are the best preforming and durable crawler of these two ? and why?
08-15-2009, 07:14 AM | #2 |
Durability, hands down no question the Rock Force. HOWEVER! Other than that the Kyosho has not one feature that is better than the Losi. The Rock Force isn't suited to carry the trail of broken CVD's the Losi will leave behind. Out of the box the Rock Force is a $300 kick in the crotch. It will take you another $500 to get the Rock Force to be half the rig the Losi is. I own both, don't even consider for a second buying the Rock Force PLEASE! |
08-15-2009, 08:26 AM | #3 |
Rock Stacker Join Date: Jul 2009 Location: Munfordville
If ya buy one double check everything in the Losi section. If ya have bad spools and V1 CVDs PM Rich he will get ya fixed up This crawler is absolutely amazing box stock ( with the right CVDs/spools installed).
08-15-2009, 08:50 AM | #4 |
ok ! so i'll pick the losi ! whitch are the stongest cvd's , shaft's and spools for this rig then ? I have an mambamax esc and lipos that will fit this rig like a glove !on the motor front i have some drill'ish motors from an newage crawlerkit and traxxas 23t titan 550's would one of these motors be good ? |
08-15-2009, 08:59 AM | #5 | |
08-15-2009, 09:48 AM | #6 | |
Rock Crawler Join Date: May 2006 Location: Georgia
If you decide to go with the Losi TCS has them on sale cheap. http://www.tcscrawlers.com/In-Stock-...1-p-17215.html | |
08-15-2009, 10:01 AM | #7 |
hm but What's the bad things about the rf ? and what makes the lcc so mutch better ? the losi cc aren't aviable here in sweden :-( but i could order one from usa ofcourse but then i have to wait week's for spareparts grrr ! |
08-15-2009, 11:47 AM | #8 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
wait for the losi. the rockforce is as harley said" a $300 kick in the crotch" although i invested more than double that and it still isnt close to the driveability or support you will recieve from losi. go losi
08-15-2009, 12:18 PM | #9 | |
I ran a Moped esc on 2s with 13 tooth pinion with a 21 turn titan 550... worked rather well. | |
08-16-2009, 05:10 PM | #10 |
Rock Stacker Join Date: Nov 2008 Location: marin
howd u hook the motor up???? that sounds hela fun |
08-16-2009, 05:43 PM | #11 |
Rock Stacker Join Date: Jan 2009 Location: Toledo
I would go losi cc. Give it a little time and you will have tons of aftermarket for the CC. Any issues that come up with the CC will have the aftermarket if not the factory support to run things to the limits.
08-17-2009, 01:57 PM | #12 |
Rock Stacker Join Date: Oct 2005 Location: Greeneville,TN aka BFE
i would choose the losi. i dont have either of them but have seen them perform. i like the added clerance of the worm drive axles and u cant beat the dig installed out of the box. my thought would be u would have to throw more money into the rock force to make it perform as well and then u could have just got the losi and upgraded it. but whatever u choose look around both of thier specific sections and come up with ur own pros and cons. good luck |
08-17-2009, 02:14 PM | #13 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Well Let See
I would go with the Losi Comp Crawler, because I've seen plenty of them perform really well at Rock Crawling Comps. I've only seen two Rock Force rigs in comps and one of them belong to a friend. |
