Losi knuckles on AX10 Does anyone know if losi comp crawler knuckles fit the AX10. I am working on a steering project that can't use high steer knuckles, so it needs knuckles with short arms to clear the shock mounts. I know that LCCs use two bearing the same size, but is their enough material left to drill them out to 15mm. I have found hot racing does an 'oversize' knuckle with 12mm bearings, but still doesn't look like it has enough beef to drill it out. Thanks for your help"thumbsup" Kieren |
idk but the idea sounds interesting so keep us updated with some pics maybe. |
the knuckles may be the right size but then you have to deal with the drive shafts. bearing sizes. |
Bearing size is what I am most worried about:? Would be nice if I could get it to work. Why couldn't losi have made them the same:mrgreen: I'll just keep looking see what I can find. Kieren |
