01-04-2006, 09:41 AM | #21 |
Newbie Join Date: Nov 2005 Location: The Netherlands
posted a short vid of the truck on rcpics. needs a little more ground clearance and a 8 tooth pinion, do the HPI one's fit? http://www.rcpics.net/img/71225 |
01-05-2006, 06:14 AM | #22 |
Rock Crawler Join Date: Sep 2005 Location: IDK
thats a preety nice vid there koop andesr gewoon een tlt-1 bodie die staat vast wel leuk op je grote wielbasis en als je wat beter ground clearecnce wilt maak de voorkant gewoon wat korter of allebei de kantne dan komt ie eat hoger te staan Heey here i am again helo earl can u post some pics of the wideners u use i see that the wheels are grabbing the bricks verry well what is that tricking noise that your vmg make wheen getting stuck?:? im realy intrested in th ewiderners and adapters please post pics groetjes uit sgravanzande(westland) |
01-09-2006, 11:19 AM | #23 |
Hey crawlrookie, here's a close up of awheelwhidener, I got myself some alu hexes and made some wideners out of solid steel rod which I attached with M3 grub screws on the flat side of the axleshafts |
01-09-2006, 12:04 PM | #24 |
ooow thats soooo cool please make a set im teeerrible in need of them please make me four. ik woon tog ook in nederland en je kunt ze dus zonder te veel moeite versturen hoe duur woore se dan eigenlijk ajb please maak se voor me |
