08-29-2009, 06:32 AM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Essex, UK
| Eliminating torque Twist - opposing trans outputs?
Ok, so I'm planning a build at the moment and I want ZERO torque twist (it drives me crazy! lol) I seem to remember reading somewhere that if you had a transmission/transfercase with opposing direction outputs, it would cancel out an torque reaction from the motor. I should imagine that you would have to flip over one of the axels to keep things going in the right direction. I have looked around, but cant seem to find any information on said idea or if there even if such a trans exists. Does anyone know anything about this? Any info welcome Thanks |
08-29-2009, 06:41 AM | #2 |
eliminating torque twist in 2 easy steps... 1. buy MOA 2. enjoy sorry, i bring nothing to the table. |
08-29-2009, 06:54 AM | #3 |
LOL, thanks for looking... MOA is not an option for me I'm affraid. |
08-29-2009, 06:55 AM | #4 | |
Rock Crawler Join Date: Jul 2009 Location: talladega AL.
08-29-2009, 07:05 AM | #5 | |
Didnt mention it as thought peeps would just be talking trannys... | |
08-29-2009, 07:37 AM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
I don't think your theory is sound:?
08-29-2009, 07:44 AM | #7 |
Oldhippie: Its something I read a while back, I'm just checking to see if its a well known practice or something that was just a theory. The idea seems to ok in theory, just dont know if someone has done it, or if there is such a tranny.
08-29-2009, 07:55 AM | #8 |
Rock Crawler Join Date: Jan 2007 Location: Secret Crawl Location Deep In England
Twinset on this board and Eggressor I believe have both come up with counter rotating transfer cases. Il see if I can find them...... Belt Buckle Crawler (no pics tho its an old thread) http://www.rccrawler.com/forum/showt...light=transfer (newer one) Last edited by littleskull99; 08-29-2009 at 08:01 AM. |
08-29-2009, 08:58 AM | #9 |
Torque twist is worst going up or down steep hills. When going up or down steep hills, the majority of the weight and therefore traction is on the downhill tires, and very little weight and traction is on the uphill tires. Since nearly no weight and traction is available on one of the axles, there's little or nothing for the counter rotating axle to counteract. Bottom line, you'll still have torque twist. Just preload the driver's side rear shock (for going up hills) and passenger side front shock (for going down hills) and be done with it. |
08-29-2009, 10:01 AM | #10 |
Littleskull: thanks very much for posting those links mate, was beginning to think I had dreamed it! lol makes for very interesting reading. Is Eggressor still selling these? I also found this: http://www.rc4wdstore.com/2/product_...roducts_id=545 would this do the trick if the right shaft was used for the input drive? I read that the Axial axel might be troublesome for this, as there are no mounting points for the top link once flipped over. |
08-29-2009, 10:13 AM | #11 | |
Most torque twist can be dialled out with link geometry and shock setup. Matt | |
08-29-2009, 10:34 AM | #12 |
Do you think its more hassle than its worth?
08-29-2009, 07:13 PM | #13 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
Yes i even tried the whole 2 tranny idear with one axle flipped. Didnt help much, and was too heavy in the belly with 2 motors in there |
08-29-2009, 07:38 PM | #14 | |
08-30-2009, 04:33 AM | #15 | |
This is not the case with a 1/10th RC. We use transmissions/t-cases that have the motor DIRECTLY mounted to the unit. If you flip the transmission around, then you'll simply move your torque twist from one side to the other because you are changing the direction the motor rotates. Even if you flipped around your motor/tranny/t-case, you do not need to flip an axle...you can change the polarity of your motor by either switching the wires or flip the switch on your Tx. The best modification to eliminate torque twist on a vehicle running Axial axles is to install a set of overdrive diff gears in the front axle: http://www3.towerhobbies.com/cgi-bin...I=AXIC3401&P=K These will turn the tires slightly faster in the front than in the rear. To date, this is the best modification that I have found to eliminate torque twist. It wont, eliminate TT in reverse... Hope this helps. | |
08-31-2009, 07:55 PM | #16 | |
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
09-01-2009, 04:01 AM | #17 | |
09-01-2009, 04:17 AM | #18 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Torque Twist is not a product of which directio the motor or driveshafts spin. It is simple a representation of weight transfer. The tires dont know where the pinion is, or which way its rotating, all they know is the amount of torque/power being applied to them. Having a counter rotating driveshafts wouldn't make a diffrence, because at the end of the shaft is the pinion... upside down or rightside up doesn't matter, the tires are still going to spin in the same direction. The pinion is going to see the same forces, they transfer the same forces to the ring gear, out the axles and on to the tires. The tires are gonig to hook up in the same way when power is applied to them, causing the weight of the vehicle to transfer rearward, the fact that the tires have traction and are moving the same direction means that you will still have the same TT with any kind of shaft drive you have. |
09-01-2009, 04:19 AM | #19 |
| I beg your parden, You are correct. I thought it was a two gear trans.
09-01-2009, 04:39 AM | #20 | |
Like I said earlier, the best method of eliminating TT is to install the overdrive gears in the front axle. Those gears have damn near eliminated the TT in my axial... | |
