Thread: Pneumatic steering?
Old 11-23-2005, 11:45 AM   #1
Default how far does a servo travel?
i need to know how far a servo travels in inches. im planning on blowing all my christmas money away on pnuematic steering for my tlt/maxx and i need to know how big of a cylinder im going to need.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 11-23-2005, 11:51 AM   #2
servos dont travel, they rotate. the longer horn you put on it the more its end will travel but you will loose torque.
Frakk is offline   Reply With Quote
Old 11-23-2005, 12:01 PM   #3
o yeah i forgot about that.
anyway heres what im planning on getting
the kit
http://www2.towerhobbies.com/cgi-bin...?&I=LXET22&P=7
i might buy everything individially so i dont get the valve because that vavle is the wrong valave and its an extra $20.
the valve i need (2 way):
http://www2.towerhobbies.com/cgi-bin...?&I=LXET30&P=7
and the cylinder:
http://www2.towerhobbies.com/cgi-bin...?&I=LXET28&P=7
Old 11-23-2005, 12:20 PM   #4
iS IT GOING TO BE PROPORTIONAL??? How long do you think a tank of air will last?? Cool idea but there might be some problems. I think you will lose the ability to only turn the wheel halfway instead of fully. Even if you close the valve at halfway, there will be nothing supporting the piston and it will have freeplay in it. Thats what I'm guessing, at least.... I might be wrong. If you get it working, be sure to post pics and a video.
xjnation is offline   Reply With Quote
Old 11-23-2005, 12:44 PM   #5
air compresses, hydraulics dont. servo travel would depend on how hard you throw it and if it's still in the truck. huh grizz.
chafey is offline   Reply With Quote
Old 11-23-2005, 12:44 PM   #6
the valves have a control, the less air you put in the piston the less it will travel but that air stays in there not allowing the piston to move. this is experimental still. it has been done before so i know there is a way to get it to work. there are valves that control how far the pistons move so im going to one and plus its a two way. the wait tank should last for a good amount of time seeing that they have the pressure to hold up 20-30 pound planes and retaract/put out the landing a gear a few times before needing refilling. plus i plan on getting a few tanks.
Old 11-23-2005, 01:51 PM   #7
i got the final list and the total is about 70 after tax. not bad.
this kit http://www2.towerhobbies.com/cgi-bin...?&I=LXET21&P=7
with this cylinder http://www2.towerhobbies.com/cgi-bin...?&I=LXET28&P=7
and there other stuff like threaded rod and rod ends but thats included in the $70.
if i do go with the pneumatic steering, its only going to be 2ws. maybe 4ws if i get the money and intelligence to do it.
Old 11-23-2005, 03:05 PM   #8
Hmm..Why not stick with the conventional servo with links?
WestCoastPJ is offline   Reply With Quote
Old 11-23-2005, 04:06 PM   #9
because that is just plain. some of us want to do something outstanding from the rest and some just lay back and go with the flow and do the old tricks over and over again.
Old 11-23-2005, 04:13 PM   #10
I thought of doing this a while back too, using some robot pneumatics, but I don't have the balls to actually go through with it! Good job. I hope it works out well.
AdamF is offline   Reply With Quote
Old 11-23-2005, 04:26 PM   #11
beady eyes and flapping head!
Old 11-23-2005, 05:56 PM   #12
like frakk said its just too boring.
i remember seeing someone else's rig with the pneumatic steering and since then ive always wanted to try it. it doesnt really seem that hard as long as you stick with 2ws. if forget whos rig it was but it had 4ws and each axle was controlled indiviually. the pneumatic steering also has A LOT more torque. the hitech 645 servo puts out about 6.625 pounds of torque and the pneumatic and the 1" cylinder ill be using (http://www2.towerhobbies.com/cgi-bin...?&I=LXET28&P=7 ) puts out 11 pounds of torque at 100 psi
Old 11-23-2005, 06:50 PM   #13
i found it, but his was done with hydrolics. its JIA's rig
http://www.projecttwin.com/Scorpion_...awler_5081.cfm
Old 11-23-2005, 06:59 PM   #14
o yeah and looking at the steering setup on JIA's crawler, it looks as if im going to need 2 cylinders. so its actually going to cost about $90 which isnt bad seeing that itll have a lil less than twice the amount of torque as a 645 servo.
Old 11-23-2005, 07:16 PM   #15
Colt Python/SR9c
TwistedCreations's Avatar
ummmmmmmmmm ok
TwistedCreations is offline   Reply With Quote
Old 11-23-2005, 07:33 PM   #16
i know im babbling, but i just wanted to let people know that are interested, if anyone is interested.
Old 11-23-2005, 08:08 PM   #17
i need to know if this is correct.
if you were to pretend that the cylinders were mounted to the front of the axle and you were looking at the axle straight on, they would be turning to the left, am i right?
Old 11-23-2005, 09:37 PM   #18
06 Super National Champ
JasonInAugusta's Avatar
Thumbs up
I used two cylinders per axle because hydraulic cylinders are stronger when pushing than they are when pulling. Putting two on the axle gives me a rated output of 14lbs of linear force @ 100psi. I've upped the psi (easy to do on the pump itself) so I'm looking at 150-200psi in the system.
I've seen pneumatic systems work in other applications...one guy had a set of four cylinders that lifted his computer case off the desktop.
I'm not sure how many left/right cycles you'd get with the Robart system. Might want to search google to see what you can find out.
I don't think controlling the system will be an issue. As far as control it should work exactly the same as the hydraulics on my Scorpion. The pressure from the canned air (my pump) is constant, you're just manipulating the volume of air and the rate at which it travels. You will end up giving more steering input than you ever have. With the type of system you're thinking about running, it will not return to center. It'll stay pointed in whatever direction until you give the opposite input. It'll be like flying a helicopter, you'll have to counter every input you give to keep it moving straight.
The main (and it seems only) problem I see is that air compresses. Hydraulics work because the fluid is incompressible. Pneumatic setups work great for airplane retracts because there's very little work to be done. On a crawler it takes a good bit of force to steer with authority.
Then again...that dude did lift his computer case with 4 cylinders.
I say give it a shot...but put the cylinders on a behind the axle setup. No sense in beating them against the rocks.
Can't hurt to try.
If it helps, here's the plumbing diagram for my Scorpion. There's a couple of things missing, but you won't need them on your pneumatic system anyway.
JasonInAugusta is offline   Reply With Quote
Old 11-23-2005, 10:36 PM   #19
After reading the topic which is "How far does a servo travel?" I'm thinking this..
Servo travel isn't important in your system.
What is important is how much linear travel you'll need to move the steering knuckles from one point to another. If I remember right, it's ~ 34mm
Then you'll need to know the stroke of the cylinders, as well as their eye to eye length when extended and compressed.
This will tell you if the cylinders will even fit the axles.
Old 11-23-2005, 10:39 PM   #20
yea ik all that this tread wasnt supposed to get into such detail.
