09-07-2009, 03:05 PM | #1 |
Rock Stacker Join Date: Aug 2007 Location: shoreline
| Solar powered rig
he everyone, im thinking about turning my crawler into a solar powered one for my high school senior project, think its possible?
09-07-2009, 07:16 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
Anything possible, dude, if you put your mind into it. Good luck |
09-07-2009, 07:32 PM | #3 |
Rock Crawler Join Date: Aug 2007 Location: Atlanta
Awesome! I would suggest a MRC build. 540 motors will probably soak more voltage and amps than a little motor will.
09-07-2009, 07:40 PM | #4 |
Pebble Pounder Join Date: May 2009 Location: South Gap
I say go for it Do the research and i'm sure you will figure out a way to make it happen. Be sure to post up some pics of your project. good luck!
09-07-2009, 07:44 PM | #5 |
RCC Addict Join Date: Sep 2008 Location: Mccalla,Al
Go for it, Then post it up, would like to see that I think it will be sick. |
09-07-2009, 07:52 PM | #6 |
Newbie Join Date: May 2007 Location: New Zealand
The major issue i can see here is that the area of solar panel required to drive the motor would be quite large. Im unsure how long charge times would be or if the sloar would keep up with the discharge rate running the motor/servo. Are you planing just a solar powered car or powering the transmitter with solar also? Sounds like a neet project and i would be happy to help out |
09-07-2009, 08:03 PM | #7 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
i don't know anything about solar, but i will be watching this thread to see if you decide to give it a go. good luck and hammer down ! |
09-07-2009, 08:56 PM | #8 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
I think its a great idea. You can crawl all day long!
09-07-2009, 08:59 PM | #9 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
If you're not worried about how much space and weight it takes up, then yeah. You could certainly do it.
09-07-2009, 09:23 PM | #10 |
thanks for all the replies! i was thinking a 8.5 x 12 inch solar panel that could be connected to the battery, i would think it a success if i got just a little bit longer run time. i would just try to attach it to my existing crawler though
09-07-2009, 09:43 PM | #11 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Subscribed |
09-07-2009, 09:47 PM | #12 |
so i have been looking around i thought i found one that was the perfect size but it turned out to be like .8kg which is around 15 pounds lol.. little bit too much weight. so now im thinking a little smaller like maybe this http://store.sundancesolar.com/susoce0500ma.html . i could get like 6 of them because they are small and make a sort of harness. but that might be more wiring then its worth
09-07-2009, 10:32 PM | #13 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
awesome idea!!! i think you should try it, but youll have to find a stonger panel than that i think or use more of them, the link you posted those cells are for .5 v youd have 3v with 6 panels?
09-08-2009, 04:04 AM | #14 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
What, no night crawling!!:-P
09-08-2009, 05:22 AM | #15 |
RCC Addict Join Date: Nov 2007 Location: E.T.R.C.
Very cool project I hope you do it How about this panel http://store.sundancesolar.com/6vol100mafle.html And this body if its a 2.2 rig... http://www.shop.rpphobby.com/product...categoryId=114 Might work |
09-08-2009, 08:00 AM | #16 | ||
Quarry Creeper Join Date: Aug 2009 Location: Palo Alto, Bay Area
Again, that woudl increase your run time very minimally. It output 100mA max. That means a total of 100mah extra per hour. if you run down your batt in 30 mins ussually, (1500mah pack), that would give you 50mah extra, boosting your runtime to about 31mins. (1500mah / 30min = 50mah per min is rate of use). | ||
09-08-2009, 08:08 AM | #17 |
Quarry Creeper Join Date: Nov 2007 Location: Funky Town
| I have a working Solar Rx batt charging system. 3 solar panels charge the Rx batt while in the sun...(click my Earthroamer Link) Solar powered wont work for torq, you can charge batteries with solar, and use the power from the battery, but Eventually it will run out. I could put 2 pages of reply on this, I was apart of a solar challenge in school years back. The vehicles that are only solar powered (no batteries) move extremely slow (no torq) to get moving then rely on aerodynamics and a very expensive surface maximizing solar panel to juice the motors. The slightest bit of shade can drop them from 60mph to 40mph in seconds. Solar charging additive YES, Solar powered crawler... probably not. |
09-08-2009, 08:22 AM | #18 |
Ya, you will definetly have to use the solar cells to charge the batts, you can't eliminate them. But I jsut got an interesting idea. Have a bunch of trailers carrying the solar panels, and instead of hitching them as ussual, hitch them via a rear winch. Then, when you actually have to crawl over something, let the winch line out, crawl over it, and then use the winch to pull the trailers over, lol.
09-08-2009, 09:21 AM | #19 | |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
But don't try to power the vehicle with it. 100-200ma will not take you far. Go with the project as a "Run Time Extender".
Does anything happen to the panel(s) if they are not getting light and generating output but being backfed from a battery? | |
09-08-2009, 10:53 AM | #20 |
Newbie Join Date: Aug 2009 Location: Humble
I have a Solar cell on my sons boat. (walmart brand) I have yet to see it run out of power. He only drives it for 15-20 min at a time. I replaced the stock battery set-up with a Traxxas Revo servo 5-cell 1100mAh. Here is some with 400 mA rating http://scientificsonline.com/product.asp_Q_pn_E_3039810 |
