Thread: Ax-10 Scorpion Steering
Old 09-15-2009, 12:56 AM   #1
Default Ax-10 Scorpion Steering
I bought a aluminum servo horn for my Ax-10 but when i went to install it. It was hitting the lower steering bar. So I dropped the bar lower so it would fit right but now I'm thinking it my be down to low. So maybe I should raise the servo and but everything back to the way it was. I guess I'm asking what to do? or is it OK the way it is.
rockn is offline   Reply With Quote
Old 09-15-2009, 01:16 AM   #2
isnt that a axial not a berg
dunerdude69 is offline   Reply With Quote
Old 09-15-2009, 03:28 AM   #3
Location: You will never find a more wretched hive of scum and villainy
the bottom pic is how mine is set up
DeweyCJ5 is offline   Reply With Quote
Old 09-15-2009, 05:17 AM   #4
On the lookout for Rocks
constantmotion's Avatar
Everything with the new servo horn looks good. I am not seeing any sort of issue.
constantmotion is offline   Reply With Quote
Old 09-15-2009, 08:47 AM   #5
I would try to get the tie rod up on top the knuckle arms. Might be able to use the shorter hole on the new arm and cut the outer one off. Raising the servo will raise the cog, not a good idea. Flipping the arm up will also work.
oldhippie is offline   Reply With Quote
Old 09-15-2009, 08:57 AM   #6
id defitnaly use the upper hole in the servo arm and trim it
2500hdon37s is offline   Reply With Quote
Old 09-15-2009, 09:10 AM   #7
Flip the horn 180 degrees so its pointing up and run a longer link to the other side? The horn will probably hit the ground when you flip over though, maybe build a loop over top. That will allow you to run the link on top of the knuckles, maybe even with a spacer too.
Raising the servo will affect the CG a little, maybe.
phillyb is offline   Reply With Quote
Old 09-15-2009, 03:53 PM   #8
keep it the way it is in the lower pic.
its gonna get you hung up occasionaly so low, and eff up some approach angles.
take a basic BIC pen apart, and slide the white body part over you lower steering link. that will help you and your link there to "roll over" stuff, until,
you chalk up and get some VP High steer knuckles lol
BEELZEBOB is offline   Reply With Quote
Old 09-15-2009, 04:36 PM   #9
Default BIC pen
I think ill go withit the BIC pen for now. Thanks
Old 09-15-2009, 04:39 PM   #10
hey it works lol
