11-28-2005, 07:20 PM | #1 |
Newbie Join Date: Nov 2005 Location: Denver
| Run Time
I just bought 2 of theses, 1 of each. how much run time can I expect out of one charge, also where can I get extra batteries. thanx Last edited by 2fastlx; 11-28-2005 at 07:46 PM. |
11-28-2005, 07:42 PM | #2 |
Pebble Pounder Join Date: Nov 2005 Location: VICE PRESIDENT of clodtalk
the stock batteries dont last too long, they are 600 mah. i just switched mine over to rc18t electronics with an 1100 mah battery and get excellent runtimes. not sure if you can use an 1100 with the stock electronics or not. i switched mine to a high torque servo so i had to do the switch anyways. i might have a couple xtra batteries that i wont need. i'll let you know. cam.
11-29-2005, 02:35 PM | #3 |
Pebble Pounder Join Date: Nov 2005 Location: NHFF World HQ, TN
| longest run time ever!
I was a WM looking for a scorpion, ( i have a jeep) and found some discontinued TYCO 7.2v battery packs and chargers for $3, yes, $3 !! they are made of C-cell size batteries arranged end to end in 2 stacks of 3. I turned it on its side and used the Dremel to cut the "transmission tunnel" and center of the dash out. i put velcro on the bottom of the battery just to keep it from rattling, the body holds it in very well. Anyway, after a full charge it will run for about AN HOUR AND A HALF. I actually got tired of playing with it before the battery died! that is a first for r/c 's I went back and bought 2 more of the TYCO packs and chargers.
11-29-2005, 11:20 PM | #4 |
Rock Stacker Join Date: Sep 2004 Location: oil city
Run time mabey about 30-45 min. I'm not sure on stock electronics. I made my own pack out of rechargeable ni-mh. They say 2500 mah. I havent got a chance to test them fully but they do work. TBItoy: How is the performance with those. They have to be hella heavy. Does it have a super high center of gravity and flip easy? |
11-30-2005, 03:16 PM | #5 |
No not that i notice it. I did a belly up as far as i could without remounting the suspension. And then lowered it till i have about 3/8 inch compression left in the springs. i will charge up the stock battery and put it under the dash (I modified so it would fit too) and see if it makes a drastic difference. Oh, i ran it last night for 2.5 hours!! It seems to be getting longer run times with more cycles.
12-12-2005, 03:50 PM | #6 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
| From the manual 6 cell x 650 mah nicad
Normal operating current 3.8 amps Normal operating duration 25 minutes I am doing preliminary testing now and will update with AAA batts also on my findings. My stock battery is usually over 650 mah and works well. |
12-12-2005, 04:33 PM | #7 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Last run with my stocker, crawling over random stuff inside the house, I got 17 minutes before it started to slow down, and 2 more minutes until it stopped working completely. So that's 19 minutes. This was run in low gear the whole time.
12-12-2005, 04:40 PM | #8 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
I usually get around 1-1/2 - 2hrs of runtime from both of them I have.
12-12-2005, 04:44 PM | #9 |
Wow...with the stock battery? how the heck do you do that? I charge mine with my Superbrain 959 charger that I use on all other rc batts, at a charge rate of .5 amps (anything higher and it false peaks)
12-12-2005, 04:49 PM | #10 |
| stock runtime
I just got thru climbing in the house, low gear only and got 35 minutes. No stopping other than to flip it over. I am chargeing a 7 cell 700 mah pack of AAA right now.
12-12-2005, 04:53 PM | #11 | |
Quarry Creeper Join Date: Aug 2005 Location: classified
Really??? I use the same charger @ 1amp with the normal 5mv per cell threshold and I never false peak. I get at least 30min+, after that I get bored so I don't know how much longer it would go. | |
12-12-2005, 04:58 PM | #12 |
I've been chargeing at .5 - 1 amp and getting around 750-800 input, haven't discharged test (just in the truck) If I used 600 mah and 35 minutes it was a average discharge of around 1 amp. Did I figure that right? |
12-12-2005, 05:27 PM | #13 |
OK..I just charged it again, .5mv, 1.0amp, and it took 4 minutes start to finish. Is it fully charged? Or did it false peak? The battery pack is still cold to the touch, not even warm. Nope...that diddnt work. Only lasted 5 minutes on that charge. I usually have to restart the charger twice to get a full charge. Last edited by AdamF; 12-12-2005 at 06:06 PM. |
12-12-2005, 06:49 PM | #14 |
1 amp should take around 40 minutes to deliver 650 mah.
12-12-2005, 06:51 PM | #15 |
| 7 cell x 700 mah
stock pack weighs 112 g 7 x 700 AAA weigh 106 g I just tested the run-time on the first charge and found a bad cell, it ran 21 minutes and all the other cells had around 100 mah left. I just made a new pack, put a chargeing jack on the truck cuz I am tired of unplugging batteries and taking off the batt door. |
12-12-2005, 08:06 PM | #16 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
So far, I have only run the stock pack, charged with the stock charger. I charge it for 5 hours , and that gets me around an hour or so, depending on how hard I crawl.
12-13-2005, 09:30 PM | #17 |
second run with 7 AAA was around 17 minutes, all low gear and constant climbing and crawling. I found out too that my cells are only around 500 mah (they are supposed to be 700) 650 mah at 3.8 amps is 10 minutes right? |
