09-24-2009, 07:54 AM | #1 |
Newbie Join Date: Oct 2007 Location: pHILLIPSBURG
| losi 8ight Buggy shocks on crawler??
I have a set of Losi 8ight Buggy Shocks lying around and was thinkin about slapping them on my custom crawler/ rock racer...would this work properly and limit articulation a bit or am i wastin my time? Right now i have stock axial shocks and wanted to lower the rig slightly..thanks
09-24-2009, 07:59 AM | #2 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
I thought about the same thing, my buggy came with two sets of shocks - one standard and one big bore 16mm set. I deemed that even the small standard set would be too large in diameter for my liking. If they will fit your truck I say try it out!
09-24-2009, 08:03 AM | #3 |
ill have to see if i can shoehorn these badboys in....they would look good tho
09-24-2009, 10:07 AM | #4 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
Aside from the spring rates being too stiff, you'll probably run into clearance issues when the front tires are turned and the shock is compressed. But try it anyways, I'd like to see just how big those shocks are |
09-24-2009, 10:47 AM | #5 |
Tire rubbing was my concern as well, I already have my shocks inboarded so they don't rub. I also considered running the springs internally. I believe I am actually headed in the opposite direction, with smaller shocks like the pro-line scaler shocks, with internal springs.
09-24-2009, 11:00 AM | #6 |
ok im gonna play with this later tonite and report back....prolly be a exercise in futility. Maybe ill try to rig up some internal springs in the losis and see if that changes the stiffness of the spring rates.
09-24-2009, 01:56 PM | #7 |
Newbie Join Date: Mar 2008 Location: Bloomington, IN
Does anybody know if Associated shocks will work on the AX10? I havent Gotten my AX10 yet, but I am more experienced with Associated shocks. Search didnt turn anything up. Thanks.
