09-29-2009, 05:45 PM | #1 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
| need some looooooong screws
ok i need some m3 x 63mm and m3 x 70mm. i've looked everywhere and the longest i can find is 50mm. i'd even settle for some m3 allthread. any help is appreciated. |
09-29-2009, 07:54 PM | #2 |
09-29-2009, 08:14 PM | #3 |
Can I ask what you need such long bolts for? There might be a better way to accomplish what your after.
09-29-2009, 08:15 PM | #4 |
the heli dept at the local hobbytown had screws that long when i needed some.
09-29-2009, 11:36 PM | #5 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
Why so long???? |
09-30-2009, 08:34 AM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
| http://www.mcmaster.com/#socket-cap-screws/=3uujkz http://cgi.ebay.com/Associated-M3-X-...QQcmdZViewItem http://www.carpentercreek.us/product...productId=1539 Google is your friend Last edited by oldhippie; 09-30-2009 at 08:37 AM. |
09-30-2009, 11:51 AM | #7 |
09-30-2009, 12:12 PM | #8 |
09-30-2009, 12:12 PM | #9 |
Rock Crawler Join Date: Aug 2008 Location: Tucson
Quick fix would be your local ace hardware store. They rarely have metric allthread but they commonly have 4-40 in stock. I feel ya because I was in a similar situtation. The 4-40 is a little bigger than 3mm and not as big as 4mm. Dont forget to pick up the 4-40 nylon locknuts while your there and some washers. The 3mm or 4mm locknuts your probably have wont work on the 4-40. Post up some pictures of whatever you come up with. And if one store doesnt have it, try another store. Some ace hardwares carry stuff that the others dont. |
09-30-2009, 12:33 PM | #10 |
09-30-2009, 01:30 PM | #11 |
09-30-2009, 01:57 PM | #12 |
09-30-2009, 02:03 PM | #13 | |
If not,3mm drill rod and 2 set screws would be the hot ticket. If these bolts hold the plates on,still use the drill rod deal with set screws then drill and tap the skid and plates to either 4 or 5mm and use short bolts to hold the plates on with the bigger hardware. Slick as a ribbon. This way,you wouldn't really need the set screws as the bigger hardware would hold the rod in place. | |
09-30-2009, 05:24 PM | #14 | |
im trying to this on a sss chassis and the one on my rock force. | |
09-30-2009, 07:23 PM | #15 |
Yes my brain (and body) is fried |
09-30-2009, 07:37 PM | #16 |
09-30-2009, 07:43 PM | #17 | |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
x2 they have alot of stuff like that. | |
09-30-2009, 09:48 PM | #18 | |
of course this is the before shot using 30mm m3 associated screws. But basicly just drilled all the way thru the rod using a m4 drill bit, threaded the 4-40 rod thru, cut off the ends with the dremel and now its tight and solid. | |
09-30-2009, 10:04 PM | #19 |
09-30-2009, 10:13 PM | #20 |
