| | #1 |
| Quarry Creeper Join Date: Nov 2008 Location: Orange
| Ok i was wondering if any one had tryed a moa setup on the axial axles(like the losi moa)? i know the gear ratio is WAY of from the losi or berg ex. i thought it would be cool to try, but i dont have the brain or the tools to build any thing like that ( |
| Sponsored Links | |
| | #2 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| You'd have to cobble a tranny of some sort to the axle in order to get your gear ratio's right. I know for a fact that it's been done on other axles and even some home brew solid axles. You can search the Twin Force section,I know there was a build in there a good while back. Could it be done,probably. It'd take allot of custom work and parts I would think to do it right. |
| | #3 |
| Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
| the biggest problem would be the gear reduction. the axial axles have a 2.92 ratio, but the actual ratio of the truck needs to be 40:1-70:1. losi axles use a worm gear and are around 40:1, hence why moa is easy with them. |
| | #4 | |
| Black Label Crawlers ![]() Join Date: Sep 2008 Location: behind the wheel of a monster truck...
X2...On all that..Could be done,yes i'm sure..But would it be worth it?..Probably not.. | |
| Thread Tools | |
| Display Modes | |
