| | #1 |
| RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
| I've been playing around with shock setup on my Berg while I do a rebuild on a new chassis. I'm running a CDW chump chassis and 103mm HPI shocks with Losi white springs. I've always run my truck fully sprung. The shocks are at full extension when the truck is sitting at ride height. Lately I've noticed that some build threads are mentioning two measurements for ground clearance. Ride height and "fully drooped out" these are sprung trucks but it appears that their suspension has some down travel. I usually see this mentioned on trucks running losi shocks. It looks like their spring preload collars can be backed off enough that the springs aren't holding the shock at full extension like mine do. I don't think these trucks are running a spring under the piston in a true "semi-droop" setup. Is some down travel in the shock beneficial? Does it let the wheels drop down and grab when you're hung up on the skid? Does that down travel cause the suspension to "unload" in any weird ways? What are your thoughts? Thanks. Last edited by BigB_117; 10-28-2009 at 12:14 PM. Reason: spelling |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Aug 2008 Location: On a rock
| mine is set like that... the springs are set so i have a ride height of 3 1/4".. if they were set to full extension it would have over 3 1/2" belly height and be under the 12 1/2" wheel base... and i think you mean up travel when the truck is sitting at static height.. it will lift some on accelaration and suck down you dig... |
| | #3 | |
I think I would need shorter springs to get that same effect. Even with my shocks unlimited the Losi white springs will hold the shocks at full extension. | |
| | #4 |
| If you are running HPI shocks unlimited, i think they are over 4" eye to eye...... 4 3/16 i belive.. you cant adj. the threaded spring adjusters all the way up to the top of the shock? |
| | #5 | |
I've always run the preload collar all the way up, but it doesn't go up as far as the Losi shocks because of the screw on shock caps. I mocked them up with no limiter but it put me way too high. | |
| | #6 |
| maybe a shorter spring from a 3 1/2" shock??? or lay the shock back one hole to soften it a bit... |
| | #7 |
| | #8 |
| Thread Tools | |
| Display Modes | |
