| | #1 |
| Here for booBs-n-Bacon! ![]() Join Date: May 2009 Location: Roseburg, Oregon
| I've used the search tool here looking for hardened gear sets for an Axial trans, but have come up empty handed. Could someone please point a fellow wheeler to the right on-line vender to order them from. Any help would be great. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
| robinson racing makes gears for the ax10 tranny |
| | #3 |
| Dream...Think...Create. ![]() Join Date: Jun 2007 Location: Crawler Innovations, Tyler, TEXAS
| The Crawler Store sells the Hot Racing hard anodized aluminum gears. They have held up to brushless outrunners on 3S and 4S Unfortunately TCS is out of stock currently, but here is what I would recommend: http://www.tcscrawlers.com/Hot-Racin...T-p-16821.html I have also used the Integy gears, although I hate to admit it http://www.tcscrawlers.com/Integy-He...8-p-17293.html Those are in stock and you get a steel spur gear as well. The problem with the Integy gears is that the output gear is drilled different and you will have to enlarge the holes to work with a standard Axial output or CDW output. Those are your two best options in my opinion. RC4WD makes steel gears, but there third output gear has the outputs machined into it which makes it useless for dig systems using custom outputs. Good luck, Eddie |
| | #4 |
| Thank you for the fast and informative response. I try not to buy any Integy products but I need parts asap and the will do until I can get the RRP gear set. Thanks again. |
| Thread Tools | |
| Display Modes | |
