01-01-2006, 10:46 PM | #21 | |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
the metal tub rubs up against the sides of the battery compartment. | |
01-02-2006, 05:56 PM | #22 |
Rock Stacker Join Date: Dec 2005 Location: usa
i extended my back link thing. didnt think it mattered how long it was. i just used a whole pen lol. so i cut it some more
01-03-2006, 02:30 AM | #23 |
Newbie Join Date: Dec 2005 Location: USA
I was going to do the whole pen extension after I get my other 1:18th parts truck next week but I like this set up more so I will be using it. Thanks for the great write up with pics. |
01-03-2006, 03:46 PM | #24 |
Newbie Join Date: Oct 2005 Location: Maryville
| Looks Good!!
I just went to the store and picked up the same materials you used. After getting the 2.2 completed I noticed the deffinate need for the W.B. extension and this looks to be the best looking and easiest remedy. Thanks for the tip!!
01-03-2006, 08:36 PM | #25 |
| Almost finished
Man this thing rocks now, thanks ! I do have one request though, could you show us a close up of your links that are mounted above your axle ? You have got to love these Dirt Hawgs, I think that they are about the best for these little things (I wouldnt really call mine little anymore thanks to you). I just hope that my hot glue/ zip-stripped Nylint outer lasts long enough for me to test it at my buddys place .
01-07-2006, 06:52 PM | #26 |
I wanna be Dave Join Date: Sep 2004
i have a question about this mod. after getting rid of the droop pin,how did this effect the suspenison ? what keeps the axles from dropping ? the shock ? thanks |
01-07-2006, 08:03 PM | #27 | |
Pebble Pounder Join Date: Nov 2005 Location: Orlando
That's weird, after I did mine the tubes are super close to the compartment but not really rubbing. The fall and articulate very well even under their own weight. Anything a little sanding or a small spacer will take care of? Looks like there might be some variances in compartment dimensions. | |
01-07-2006, 08:04 PM | #28 | |
Hahaha. Better too much than not enough huh? | |
01-07-2006, 08:05 PM | #29 | |
That is correct, axle droop is limited by shock extension. | |
01-07-2006, 08:16 PM | #30 | |
I just upgraded the third link again to beef it up cause I bent it a few times. Seems like Putfile is not allowing any uploads right now. Give me a little bit and I'll post the pics as soon as it allows uploads again. | |
01-07-2006, 08:16 PM | #31 |
does it poull the shock apart ? i read somwhere on here somone had this problem. im not sure if it was with this mod or not. also, any axle wrap ? thanks gain. |
01-07-2006, 08:26 PM | #32 | |
No pull apart, the 1:18th scales have a screw which hold the shocks together, the 1:6's don't. It doesn't have any increase in axle wrap from prior to this mod. With this three link design some axle wrap is always evident. | |
01-07-2006, 08:27 PM | #33 |
Newbie Join Date: Jan 2006 Location: NANAKULI MAI BOI
eh bra i just tried this mod it looks kool but havent ran it yet ill post pics when i can get thanks for the idea bra
01-07-2006, 09:52 PM | #34 |
im gonna give this mod a try. this is a work in progress so it may be a bit. keep checking "geofab" thread. thanks again. |
01-08-2006, 07:50 PM | #35 |
I joined the Band! Join Date: Sep 2005 Location: Tampa
any pics on the 3rd link(upper) mod? maby a step by step? _Jason |
01-10-2006, 08:41 PM | #36 |
01-15-2006, 02:02 AM | #37 |
Quarry Creeper Join Date: Dec 2005 Location: Orrington
did you have any problems with the wires being to short??
01-15-2006, 07:37 AM | #38 |
yep. so i un soldered um and put an extension on there and soldered um back on and geuss what i blew up the pcb lol dont desolder ur wires |
01-15-2006, 08:51 AM | #39 |
I joined the Band! Join Date: Dec 2005 Location: portland
did you do something to the gears? it seems to be going slower than stock
01-17-2006, 07:09 AM | #40 | |
Here are some pics. of the rear axle. Items used: 2 sections of aluminum rod. Inner Section HS 5/16x.035 thickwall rod. UPC 614121130356. - This rod fits into the pivot holes at the axle and can be inserted (with a small bit of coaxing) into the hole at the cross link. - You'll need to cut this piece approx 1/2" - 3/4" longer than the Outer Section. - You'll need to cut approx 1/2 of the shaft from the the outer plastic cap to allow this rod to insert into the axle pivot hole. Outer section. Same rod I used for the side links at the beginning of this thread. - Needs to be cut so that it reaches link to axle with the inner section fully seated. 6/32 All thread and 2 nuts. - Should be cut long enough to protrude from the rear link and the rear axle with the inner section installed. ****Note***** The 6/32 allthread and nut will only work if you've extended the side links. If you have NOT extended the side links then you'll need to use 4/40 allthread and nuts as the 4/40 nuts will countersink into the rear link. ****Note***** Thread Lock Blue or Red - To lock the nuts if you did not use self locking aviation nuts. Have fun. www.putfile.com | |
