Axiformer From Spain Hello friends, I leave some photos and videos of my Axiformer. http://i592.photobucket.com/albums/t...2131/017-3.jpg http://i592.photobucket.com/albums/t...2131/018-4.jpg http://i592.photobucket.com/albums/t...131/002-19.jpg http://i592.photobucket.com/albums/t...2131/023-1.jpg http://i592.photobucket.com/albums/t...2131/024-1.jpg Video: http://www.youtube.com/watch?v=aqWYRvlFmYU Thanks. |
:shock: Wow, nice work. Good thinking. |
nice...I like the concept but your cg is crazy high...roll overs way to easy....plus that battery setup is a little weird. Good engineering...not that practical imo |
errrrrrrrr i think the hole point of is set up is so he can drop the GC waaay down, in turn lowering the COG, then if he gets hung up, go up to get his belly off the rocks.....:idea: |
Pretty cool idea- Can you control front & rear separetly-and/or is it one servo per axel--- Also, what size servo you using for it ? |
Bien hecho Martinciko"thumbsup" Espero tu proximo video8) Quote:
Ya, he's got extra weight in the chassis so he's having to fight more TT, but looks like it works just fine to me. |
Thank you very much everyone, and responding to your questions, independent handles the front of the rear. http://www.youtube.com/watch?v=OaoOAcvvowE http://www.youtube.com/watch?v=kLNmyWz5mrc In high position remains to 85mm from the ground and stays in the down position to 35mm of soil. http://www.youtube.com/watch?v=jzSt0hhMDss Excuse my English because I use translator. Thanks |
lol "thumbsup" I know that, i was pointing that out to the3kid who said that Martincikos COG was far to high. |
Very cool, dose it crawl good with that set-up? |
<TABLE id=texttable><TBODY><TR vAlign=top><TD id=gap></TD><TD class=almost_half_cell>Actually, in low position and without wheels the engine is at the height of the axes, and if you put aside held vertically on the amendment of the battery has performed better this way. </TD></TR></TBODY></TABLE> http://i592.photobucket.com/albums/t...131/002-19.jpg http://i592.photobucket.com/albums/t...131/003-19.jpg http://i592.photobucket.com/albums/t...131/002-20.jpg |
For this system I have used the following materials: 4 servos TowerPro 995 1 Combo Novak Rooster Crawler (Bec 6v 5amp) 1 Esc 9 channel 2'4Gh Eurgle http://r2hobbies.com/proddetail.php?prod=rcps61207 |
I saw this system in another spanish driver, here you have the built threat: http://www.zonacrawling.com/foros/vi...t=1674&start=0 And here you have picts about the system he has used, i have gotten in the original threat : http://i127.photobucket.com/albums/p...de/0107083.jpg http://i127.photobucket.com/albums/p...de/0107087.jpg http://i127.photobucket.com/albums/p...de/2906087.jpg http://i127.photobucket.com/albums/p...de/2906085.jpg And some videos: <embed type="application/x-shockwave-flash" allowfullscreen="true" allownetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v517/ivanmil/VIDEOS%20KDD%20GIJON/KDDGIJONJAVIZONA3.flv" width="600" height="361"> <embed type="application/x-shockwave-flash" allowfullscreen="true" allownetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v517/ivanmil/VIDEOS%20KDD%20GIJON/KDDGIJONJAVIZONA1.flv" width="600" height="361"> |
Feuerradder Hello, I know Javi (Skorpion) is the Master of Masters, and I can say that the idea of doing so I gave it him, but his system rises with only 1 servo and has no independent rear forward, but if the system is very similar and really helped me and gave me ideas for my system, I finally decided it was not like yours and install independent front and rear suspensions, that car and not have it, I think he sold , Is called the Panzamovil. Greetings"thumbsup" |
Today I got to Axiformer after several weeks stored on the shelf, and I can only say that it is a wonder. http://www.youtube.com/watch?v=zsfBofAoj88</EMBED></OBJECT> |
I have seen this idea done by someone else using a "winch." Same idea, its really cool. I can see how it could help with "breakovers" when getting up and down the rocks. Do you notice it changing your "squat" and how the car climbs or, is that just CG "thumbsup" |
Is the BEC in the Rooster running the rx and all 4 servo's. I'm sure it would never come up but sounds a bit much if you happen to run all 4 at one time. If you are running a external BEC disregard this. It may not matter any ways. |
I think the word in spanish is Exelente "thumbsup" |
seems like too much work for me. Having a properly set up fully sprung setup would probably be simpler and perform better. Its a very cool idea, but I can see its flaws. In a competition situation, I really think that you'd spend too much time messin around with the GC and not enough time crawlin. |
hola eres un fenomeno la bateria aun la tienes amarrada encima del servo es lo unico feo que tiene tu coche pero aun asi fenomenal |
