12-17-2005, 09:37 AM | #1 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
| Articulating? like a farm tractor.
Hey I hope this is correct forum. I hear everyone call articulation and describe it by the number of degrees between the max angles of the axles. Anyways I am wondering if anyone makes or designs a crawler with articulating steering (like some farm tractors have) So that neither axle is a steer axle, but the chassis swivels in the middle to steer the vehicle or even both steer axles and articulation steering? Is this a good idea? I can think of one drawback being the wheelbase on the inside wheels gets very short and the other gets quite long to make it more tipsy? what do you'all think? |
12-17-2005, 09:40 AM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
That would limit the type of steering you'd have. It'd be like having both axles on a "Y" harness. Those of us who run rear steering run fully independent setups. |
12-17-2005, 01:45 PM | #3 |
why not have both if you were to do it? I have never seen a swiveling chassis.
12-17-2005, 02:13 PM | #4 |
Quarry Creeper Join Date: Jul 2004 Location: Deland
it would have to be a monster of a servo to steer a "brokenback" crawler. next time your close to a tractor that uses that style of steering, look at the hydrolic ram used for steering, it's huge for a reason. |
12-17-2005, 02:15 PM | #5 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
Yeah, you'd have to have at least one high torque large scale servo, if not multiple ones.
12-17-2005, 02:23 PM | #6 |
RCC Addict Join Date: Dec 2004 Location: Central NY
use hydralics. like JIA did on his scorpion
12-17-2005, 05:47 PM | #7 |
Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
There would also be a problem with weight transfer. All of your weight would shift to the outside of your turning path, unless you had the weight balanced over the axles. But then you would have a possible issue of aproach and departure angles suffering. If this makes any sense at all I will be surprised as I have the flu and am not very coherent.
12-17-2005, 05:55 PM | #8 |
I find on the tractor it uses a very similar size pump as a front steer tractor of the same size. It really does not take much effort, yet with no diffs at all and locked axles then it may be require lots of power. The turning radius was always surprisingly better. Another benefit was the tire tracks will make only 2 circles instead of 4, maybe that's not a benefit? The thing I wonder about the most is the outside wheelbase going long and the vehicle tipping over.:? |
12-19-2005, 08:21 PM | #9 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
with the axles locked it would be very hard to steer, the inside track compared to the outside track would cause the truck to hop really bad as the tires fight each other for traction, just like a 1:1 truck locked up front and rear hops on granite, you could try it but I don't think it would work very well, just my .02. if you could make the f/r really tight limited slip units it could work.
12-19-2005, 08:43 PM | #10 |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
| Looks like it uses a standard size servo... |
12-19-2005, 10:13 PM | #11 |
Hey there it is, that one steers everywhich way. Do you think it would have the stability with the varying wheelbase? I think it may be easier because at least the front and rear axles would be going the same distance (kinda like front/rear steer does) |
