12-18-2005, 08:32 PM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: CENTER
| 2.2 tires
can a stock nylint pull 2.2 fine?and is there anywheels that will bolt right on for 2.2?
12-18-2005, 08:35 PM | #2 |
Rock Stacker Join Date: Dec 2005 Location: Eielson AFB, AK
12-18-2005, 08:36 PM | #3 |
Pebble Pounder Join Date: Nov 2005 Location: Orlando
In low gear the Nylint can pull 2.2 with no problem. There are a few ways to make a install 2.2's on it. One involves installing 2.2 Stampede/Rustler wheels to the stock wheel, you will find that in the sticky at the top of the forum. A second quick method involves slipping 2.2 buggy tires over the stock Nylint tires. It works well, but you are more prone to body rub when articulating than with the first method. There are other methods using parts from I believe clods but will cost a little more than the methods outlined above. |
