12-19-2005, 07:52 PM | #1 |
Newbie Join Date: Dec 2005 Location: mountains
| shocks limiting articulation
i built my first crawler i used a kyosho double dare i had sitting around. it has idependent front and rear like a maxx but the motors are mounted on the axle like a clod. when the front right goes up the back right is at full extention and starts to lift ive moved this shocks up and down the links to find the best spot. id like to be able to maybe put one front and opposite rear on a pop can. ive seen trucks sitting on large cups.
12-19-2005, 11:55 PM | #2 |
Newbie Join Date: Dec 2005 Location: Osaka, Japan
Are you still using the stock shocks on the Double Dare? And you said that the right rear is lifting when you lift the right front? Is the left rear shock fully compressing? If it is not, it sounds like your suspension is too firm. (If I understand what you're saying that is.) Anyway, maybe try switching to just one shock per wheel. Your best bet would be to get rid of the stock shocks alltogether if you haven't already. Get some that you can choose springs for and also have oil in them. |
12-20-2005, 06:32 AM | #3 |
the only thing left from the double dare is the wheels and axles. i have maxx shocks. with out the shocks i have more then 90 deg articulation. right now my wb is 15.5 but its only 12 wide unlit i make spacers and change wheels. the other wheel isnt fully compressed but close i think my springs might be a little to stiff. ive seen trucks laying there shocks down or moving them to the top links i might try that. ive looked at pictures and based my orgional setup on what seemed to work. i can get one wheel 6.75" of the ground before another lifts. but when you split that between two wheels it seems pathetic.
12-20-2005, 06:38 AM | #4 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
That's plenty of articulation. If you get to much it gets floppy and rolls over a lot.
12-21-2005, 06:29 PM | #5 | |
