12-29-2005, 04:44 PM | #1 |
Newbie Join Date: Nov 2005 Location: ROCKY RICHMOND KY
| Indoor Crawler Course
Ok, It's Winter And I Have A Big Empty Basement. Can Anyone Post Up Some Pictures Of Artificial Crawler Courses Or Give Me Some Ideas Of Items To Crawl Indoors??? I Don't Want To Import Rocks To My Basement. I Searched The Forums But No Ideas. Thanks!
12-29-2005, 04:48 PM | #2 |
Get rocks in your basement That is really my best suggestion unless you have piles of kids and dirty clothes to play in. |
12-29-2005, 05:12 PM | #3 |
I Can See Now This Thread Is Going To Go Straight Down Hill. But Keep Em' Coming
12-29-2005, 05:32 PM | #4 | |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
12-29-2005, 05:39 PM | #5 |
Pebble Pounder Join Date: Dec 2005 Location: Fenton
Try and make some artificial rocks.. dont know exactly what to use though.
12-29-2005, 05:53 PM | #6 |
Quarry Creeper Join Date: Oct 2005 Location: MD
You can probably get away with buiding something out of chicken wire and wood covered with paper mache or some other material. That's what I used to build train landscapes. It should be strong enough to support a crawler. You can probably also use packing styrofoam (either liquid or solid pieces)
12-29-2005, 05:57 PM | #7 |
Newbie Join Date: Dec 2005 Location: under a bridge
12-29-2005, 05:59 PM | #8 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
12-29-2005, 06:27 PM | #9 | |
Psssst.......its on the right! | |
12-29-2005, 06:32 PM | #10 | |
Rock Stacker Join Date: Oct 2005 Location: El Paso
12-29-2005, 11:38 PM | #11 |
I wonder if that spray in foam insulation stuff would get hard enough ??
12-30-2005, 12:16 AM | #12 |
It probably would but might start to crumble or flake off. Maybe with some of that car undercoating sprayed on over the top to keep it together though. Just a thought. |
12-31-2005, 09:26 AM | #13 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
I saw some hollow landscape rocks they use to cover up sprinkler valves and stuff they have lots of sizes and shapes even different colors. I don't know where to get em but we had them out in front of my old shop.
12-31-2005, 09:56 AM | #14 |
Rock Stacker Join Date: Oct 2005 Location: bloomfield hills
i used some of that great stuff foam to make a mini crawler coarse for my zipzaps mt but im sure if u used enough you could make a decent sized coarse for a crawler...and it is strong enough to support more then one crawler at once
12-31-2005, 03:22 PM | #15 |
Quarry Creeper Join Date: Nov 2005 Location: East Quogue
When it was snowing out i used i pile of wood/ logs fo rthe fire place.
12-31-2005, 03:26 PM | #16 |
or you can cut a bunch of 8" square wood blocks and screw them to a shet of ply wood. Or get a 6x6 and cut into squares and glue 2 of them together to make them bigger
12-31-2005, 03:51 PM | #17 |
Newbie Join Date: Oct 2005 Location: Rock Crawl'n Heaven, The Big Island
Foam blocks, same as used for the SuperCrawl course for the last few years. Stack them to as large you want and cut and shape it how you want. The 1:1 courses are then sprayed with 4" of concrete "gunite". But for a RC course, you can cover it with Imperial plaster(used as a finish coat in swimming pools), it's only needs to cover the foam about 1/4" thick and is very hard. One bag of plaster can cover about 150 sq ft. and it's cheap & simple to mix & apply. When you get tired of the course, break into chunks and through it in some trash bags.
12-31-2005, 11:56 PM | #18 |
| This might be a strech but I had an idea. I have a lot of spare lumber laying around. ( family of builers) I was going to make a really hard course out of wood them roll some bedliner with sand mixed in with it for grip. You could make a pretty extreme course. |
01-02-2006, 04:55 PM | #19 |
Newbie Join Date: Jan 2006 Location: Woodbury
| Lite Rocks
I saw rocks made out of cardboard (broken, smashed, and crushed) placed in plastic bags, formed into irregular shapes and covered with spray on expanding foam insulation. These were made for a movie set and ranged from 4" rocks to car sized boulders. A little spray paint and you can't tell them from the real thing until you pick it up. Impress friends with your strength by picking up a 200 pound boulder and throwing it at them. |
01-02-2006, 05:01 PM | #20 |
Pebble Pounder Join Date: Dec 2004 Location: Medina, Ohio
I dont see the problem with using real rocks in a basement. their weight makes them stay put and they take up as much room as fake rocks. so what if their heavy?
