Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Tip, mounting pinions on a clod
Old 01-31-2004, 03:24 PM   #1
The Wheels Keep Turning
kevinlongisland's Avatar
Default Tip, mounting pinions on a clod
Here's a little trick to help mount your pinions:
Make a "depth gauge" that matches the distance from the gear case where the motor lies to the edge of the spur gear:
now, put your depth gauge up against your motor and now you know where the spur gear will be. Adjust your pinion and thats it!
kevinlongisland is offline   Reply With Quote
Old 01-12-2007, 05:12 PM   #2
your pics don't work:-( :-(
Moondust1950 is offline   Reply With Quote
Old 01-12-2007, 05:15 PM   #3
It's a setup!
jason's Avatar
Maybe because this thread is almost 3 years old ;)
jason is offline   Reply With Quote
