01-10-2010, 01:12 PM | #1 |
Rock Stacker Join Date: Oct 2009 Location: Huntsville
| stealth lockers?
does anyone know where I can find some stealth lockers?
01-10-2010, 10:01 PM | #2 |
Rock Crawler Join Date: May 2007 Location: Glendora
Check out the vendors section. A member use to make them.
01-11-2010, 02:52 AM | #3 |
Built, not bought Join Date: Oct 2004 Location: Gresham
01-19-2010, 04:14 PM | #4 |
Rock Crawler Join Date: Apr 2005 Location: Upland
You can use the Axial center transmission lockers. You might need to do some very slight modifications, but I believe they will work. http://www3.towerhobbies.com/cgi-bin...?&I=LXSAR2&P=7 |
01-23-2010, 11:22 PM | #5 |
Rock Crawler Join Date: Nov 2006 Location: Albuquerque
Check my sig. I locked a Stealth using Traxxas Stampede transmission parts. Kinda tricky but if you get it right, it works well. P.S. The idea in the post above mine looks like it would work well. Not as tricky as my idea..... |
01-25-2010, 09:00 PM | #6 |
Thanks but I'm actually using the goliath trans. just needed the outdrives. looks like I will be using axial ones.
