01-02-2006, 04:51 PM | #1 |
Rock Stacker Join Date: Dec 2005 Location: Luray
| help, rear axle not pulling
My front one my 1:6 jeep is working but my back is not
01-02-2006, 05:08 PM | #2 |
Pebble Pounder Join Date: Nov 2005 Location: Evansville
| I don't want to hear someone say, oh it's the belts, you need to put in o-rings. Do you people have any idea how to troubleshoot or are you lemmings jumping off of a cliff? Try shifting into high and back to low a few times. Lift it up, does it work with the rear off the ground? Do you hear a belt slip or squeal, a common problem is there is lithium grease contaminating the belt from the high-low gears slinging that crap everywhere. If the rear axle still does not work then the next steps depends on your abilities. Flip it over, body or not and take a look at my axle breakdown sticky. Pull off the cover and see if your shift collar is indeed moving when you shift into high and low If it is moving position and still no driving actions then the coupler with the gearbox and high/low planetary is probably stripped. If the belt is turning but the large pulley on the planetary is no turning something is busted in the planetary or you have major belt slippage. If the motor isn't turning you have a board or solder issue that can be repaired yourself or call tech support. Just try to do a little troubleshooting and get back to us |
01-04-2006, 03:18 PM | #3 |
when I hold it up my rear moves but when it hits the ledge it stops and ot goes no ware |
01-04-2006, 03:24 PM | #4 | |
Newbie Join Date: Dec 2005 Location: Abilene
Hope this helps Last edited by Jiles111; 01-04-2006 at 03:24 PM. Reason: I keint speal | |
01-04-2006, 04:48 PM | #5 |
When I opened up the rear I found the large pulley spinning on the axle. The belt is NOT slipping. I have opened up the small set of planitary gears (the one next to the pulley) and nothing is stripped in there. It is shifting from low to high just fine. Is the large pulley supposed to be spinning on the axle (metal rod) if not what happend and how do I fix it? Thank you in advance |
01-04-2006, 05:33 PM | #6 | |
Pebble Pounder Join Date: Nov 2005 Location: Here and there
01-04-2006, 10:37 PM | #7 | |
Newbie Join Date: Dec 2005 Location: San Antonio
01-05-2006, 07:40 AM | #8 |
Which pin are we discussing? The pin on the passenger side that drives the right rear tire? Or the pin that connects the high/low gearbox to the drive collar (black in first gen, white in 2nd gen, black in 3rd gen "upgraded chassis") The little tiny pin i am thinking is the one that protrudes from the blue nub on the output of the high/low planetary? Describe where in the drivetrain, I know you say the pulley is turning, is the high/low slider spinning, (white disc between high/low and the drive planetary)turning as well? Look at my axle breakdown and thing copy/paste the photo link... It can all be fixed |
01-05-2006, 05:00 PM | #9 |
Newbie Join Date: Dec 2005 Location: Eddington
This is happened to me and i went to the hardware store and bought a small hallow tube and cut it down with my Dremel and kinda crimped it down and slid it in the hole and then i took the pointed end of a nail and put it in the hole and hit it to flare the ends of the tube out some on both ends and it worked awesome its worked sense
