01-02-2006, 08:08 PM | #1 |
Quarry Creeper Join Date: Oct 2004 Location: Canada eh!
| Spring question
Hey i have one quick question for u gys, i havent got one yet but im going to be , but i keep reading you guys cut the speings, do that just make the springs softer in a way so it flexs more or more easly?or what? let me know thanks |
01-02-2006, 08:21 PM | #2 |
Pebble Pounder Join Date: Nov 2005 Location: maple valley
i donr have a nylint but..i know you can cut 4-5 coils out and get more flex
01-02-2006, 08:23 PM | #3 |
Pebble Pounder Join Date: Oct 2005 Location: Oregon
Well, I cut mine because it was the crawler was rolling over before the shocks even became fully compressed so yes, it does help with the flex as well as keeping it from rolling
01-02-2006, 08:37 PM | #4 |
Rock Stacker Join Date: Oct 2005 Location: dallas tx
it lowers the ride height, but you end up with less uptravel. spring rate is also reduced, making it easier to fully compress the shocks.
01-03-2006, 06:49 PM | #5 |
how much is a good start to cut out? and i see some guys running no shocks?
01-03-2006, 06:54 PM | #6 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
3-4 coils is a good amount to cut.
01-03-2006, 06:54 PM | #7 |
Pebble Pounder Join Date: Nov 2005 Location: VICE PRESIDENT of clodtalk
i cut three out of my 1:18th and it works well.
01-03-2006, 07:03 PM | #8 | |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
01-03-2006, 07:06 PM | #9 |
Pebble Pounder Join Date: Dec 2005 Location: CENTER
i cut three and also works very well and if there still to stiff for you you can cut another.
01-03-2006, 07:08 PM | #10 |
A 5lb-in spring is still a 5lb-in spring whether it's 4' long or 4" long. The difference is in how much weight it takes to fully compress the spring. Spring rate doesn't change. |
01-03-2006, 07:19 PM | #11 |
thanks for clearing that up JIA. it makes since though when you think about what i said. if you were to take a 5 foot piece of metal, and a 2 foot peice of metal, you could bend the 5 foot piece much easier than you could the 2 foot piece. it was explained to me that it didn't matter what configuration the metal was in, the properties remained the same. i really have no clue, was just passing along what i had been told. |
01-03-2006, 07:21 PM | #12 |
What you said regarding bending metal relates more to physics and leverage. It'll take ~20lbs to compress a 4" 5lb-in spring completely. Only ~15lbs to compress the same spring that's been cut to 3". |
01-03-2006, 07:29 PM | #13 |
works for me!
01-03-2006, 07:30 PM | #14 |
and it also matters how thick the spring is.
01-03-2006, 08:56 PM | #15 |
Newbie Join Date: Nov 2005 Location: Marin Co.
I was experimenting with springs for the Nylint the other night and I found out that If you take a spring, any spring, cut or not and stretch it out a little it WILL be stiffer. I ended up using some springs that have more "rounds" and are made of thicker metal than the Nylint springs but a similar length. These springs are MUCH softer than the Nylint springs and are working perfectly for me. |
01-04-2006, 12:24 AM | #16 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
I cut two coils off each spring, and gained an inch of articulation. The chassis only droops about a quarter inch.
01-04-2006, 12:42 AM | #17 |
My point was that it is easier to fully compress the shocks. There's no arguing that.
01-04-2006, 01:26 AM | #18 |
Yes, the way mine are now, they do seem a bit "softer". In stock form, the springs are a bit preloaded when the shocks are assembled.
01-04-2006, 01:42 AM | #19 |
Newbie Join Date: Dec 2005 Location: USA
I removed my springs completly and have been playing with it on nothing but rocks. I just need to get around to doing the wheel base extension and other things that I want to do to it and go from there. If I do like it after doing the mods then I'll throw them back on and then cut the springs down as I need to. I've been able to climb a lot more stuff with the springs completly removed and flipped the tires. I bet cutting the tires will help more as well. |
