01-04-2006, 01:23 AM | #1 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
| powering a winch
i posted this in another one of my threads, but i figured more people might see it if i post it in its own thread. is the remote and reciever on these things technically a 3 channel? if so, could the third channel be modified for use as a winch? i just "built" (figured out how im going to do it, now i gotta pick up a sheet of metal to build the side plates...) a winch, i just need a way to power it.....i was thinking that maybe i could use the hi/lo switch, and use it to switch a relay that would send power to the motor of the winch........not i could be wrong and it wont work at all....in which case there will probably just be a 3 pole toggle switch on the truck somewhere..... |
01-04-2006, 01:50 AM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: West ky, Benton
| Show U Mine
Hey man ill show u mine once we get together in the next few days but mine uses a seperate remote and elctronic for like team driving witha partner!?!
01-04-2006, 01:55 AM | #3 |
cool, you used the electronics out of a 1:18 didn't you? im trying to work with what i have, which is the gears out of an old radioshack truck and a 540 motor (probably replace it with a 65t lathe motor, or rewind this one to a high turn) god i hope they have a 1:6 at benton tomorrow..... wonder if we are the only 2 adults with these around here... |
01-04-2006, 02:04 AM | #4 |
now that i think about it, the gearing on mine might not be low enough to pull the 1:6....the 2 gears make a 5.5:1 gear ratio (8 tooth on motor, 44 tooth on pulley) maybe it would be enough with a high torque motor. i THINK this motor is a 27t, but i could be wrong. ok, im gonna quit messing with this stuff for tonight, i got a lot to do tomorrow (finish stripping a motorcycle down that i am parting out and then go get my baby) |
01-04-2006, 02:10 AM | #5 | |
lol im sure we arnt and hey i have the front axel out of the 1;18 i used for mine could u use the gear reduction out of it? or the motor or for that matte any of it? Quote:
01-04-2006, 02:12 AM | #6 | |
| can u use any of this
hey i think there are more people but i have some 1;18 parts left the whole front end could u use any of that? Quote:
