Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: It's nice having a spare!
Old 01-06-2006, 03:58 AM   #1
Default It's nice having a spare!
Ok I have 2 chassis's. I use one for wheeling and one for parts. Well I moved the rear motor on the spare one and I liked it so much I'm doing to my Wheeler. Here is the pics. Alot simpler then I thought. All you need is extra wire and a clamp. And if you think it doesn't look strong. I picked up the whole chassis by just the motor. It isn't going anywhere.
I started off at trying to put the motor in the back of the housing. Where the HI/Low motor is at. I still believe this could have been done, but with a lot of cutting. Didn't feel like cutting anymore. If you look where the belt comes through the axle the hole is a little big. Well this is by spare chassis. Who cares. Just practice. Anyway on my wheeler the hole will be a lot smaller.
If poeple want more pics of how this is done. I can post some step by step pic's if needed.
Old 01-06-2006, 04:35 AM   #2
Uhh....why did you put it outside of the axle and what's the purpose of it?
muddeprived is offline   Reply With Quote
Old 01-06-2006, 05:13 AM   #3
Ok if the motor is there and not in the front of the axle. There is no reason to keep the front part of the axle. So I'll cut it off and the rear tires will hit the rocks or steps first not the axle. I'll post more pic's later today if I get to it.
Old 01-06-2006, 05:23 AM   #4
It also helps with cooling of the engine. Mostly every other rc wheelin vehicle will have the motors outside as well. I like it. What does the clamp hold on to? pics??
icu_runnin is offline   Reply With Quote
Old 01-06-2006, 08:11 AM   #5
I like the idiea but what about the front. I mean that axle is huge and needs some serious triming done..I dont have a spare so I cant go a cuttin away at mine but if you decide to do mods to the fron let me know what worked good
http://photobucket.com/albums/d107/Toylxl2/?start=0
toylxl2 is offline   Reply With Quote
Old 01-06-2006, 09:19 AM   #6
I think I read in one of your post.. That you had did some lift..? How did you do that?
putting the motor outboard isn't bad.. Just as long as you don`t drive through any kind of sand, or anything
Dana44 is offline   Reply With Quote
Old 01-06-2006, 10:46 AM   #7
Got it..thanks for explaining.
Sounds like a good idea...maybe i'll try it on my spare chassis whenever my replacement comes. I do agree that the axles are HUGE and a PITA sometimes...
Old 01-06-2006, 11:22 AM   #8
I would like to see a few more detailed pics, mainly of how you mounted the clamp to the housing.
Thanks
Mope is offline   Reply With Quote
Old 01-06-2006, 04:11 PM   #9
ok the way I lifted my crawler:
1st I got rid of the top shaft of the shock because it was not long enough
2nd I went and got a package of bic pens because they are they same size as the shocks almost and they are cheaper than buying long travel shocks
then I went to home depot and got springs that were the same stiffness as the stock ones but 1 1/2 longer
3rd I cut the bic pens down to 4in and cut the pen cap in half to go over the top to act as a stop
then I drilled 1/8 holes in the top of the pens and mounted my new shocks
before all this I cut the body tabs and put limit straps on, I had to adjust them once I put my new shocks on..later I will have to get new rod for the bottom of the shock, it still needs to be like 1/2in longer it comes real close to comeing out sometimes and sometimes it does
go here for all my pics
http://photobucket.com/albums/d107/Toylxl2/?sc=1
I get 11 1/4 or so in of articulation after all my mods
Old 01-06-2006, 04:38 PM   #10
Where did you find the springs at HD? I searched for literally an hour and came up empty. Which deptartment is it in?
Old 01-06-2006, 08:03 PM   #11
Also, how did you mount the hose clamp to the axle housing?
Old 01-06-2006, 09:40 PM   #12
I just did it with mine and used a hose clamp, i just put two extra nylint screws into the housing, making sure one was a shorter screw to clear the hi/lo arm.
Mines pretty similar to his except i used a stock front drivebelt in the rear, this allowed me to pull the motor right up against the pivot arm so it has a little more support and is out of the way of my body, check out my recent pic thread i posted some up in there
Brian, aka XJFanatic.com is offline   Reply With Quote
Old 01-06-2006, 11:50 PM   #13
Since I didn't get anymore pic's today I'll just tell ya step buy step.
Step 1: Remove all screws and open rear axle up.
Step 2: Remove the drive motor ( it's the one with the belt on it.) And cut the 2 wires. Give aleast 2-3 inchs of wire to work with.
Step 3: Close the housing back up. Don't put the screws in yet.
Step 4: Make a hole in the housing were you want the belt to come through.
Step 5: Place the belt on the motor and place the motor where you want it.
Step 6: Take a nail and make two marks about 1/2in long on the housing. One mark on each side of the motor. (long ways)
Step 7: Now cut two slits where those marks where.
Step 8: Run your clamp and mount the motor.
Step 9: Cut the hump off the front of the axle. and cover it with something. (thin steel or plastic left over from a tummy tuck.
Step 10: Replace all screws and test drive
If you want it to be stonger just place a thin piece of steel on the inside between the clamp and the housing. That way If the motor tried to pull away it would have to rip the housing and the thin steel. I will get better pic's when I do it to my wheeler. You may have to buy a different belt. (O-ring)
Old 01-13-2006, 08:48 AM   #14
Thanks guys for the how to on the clamp mount. I'm in the process of doing mine now.
Old 01-13-2006, 11:01 PM   #15
I took all that crap out and jb welded the coupling thats the little actuator thing on the axle into low, works good, i have the motor up by the pivot point on the axle and need a shorter band because it doesnt have enough tension and is slipping, but im almost positive i can fit it in to the high low area of the housing, im gonna go mess around with it some tomorrow maybe.
Kendhul is offline   Reply With Quote
Old 01-14-2006, 03:39 AM   #16
cool post pic's when your done. I changed my mind of doing it myself. I kind of like having Hi range. Sometimes, but not much.
Old 05-08-2006, 10:03 PM   #17
i just did mine, easier than i thought it was going to be.....now i just have to shorten the belt and chop off the front of the case
am also considering chopping off the back of the case but i dunno about that yet, am going to just do the front for now......
SlammedMini469 is offline   Reply With Quote
Old 06-12-2006, 09:50 PM   #18
Question
ok, i might need some more pics, but how hard is it compared to a tt? I just did my tt yesterday, was very easy, and heard shaving the axle is essential.
SouthernHighLife4x4 is offline   Reply With Quote
Old 06-12-2006, 10:06 PM   #19
S-Dog's Avatar
if a TT is a 2 on a 1-10 scale... for Nylints the shave and motor move is a 7-8
S-Dog is offline   Reply With Quote
Old 06-13-2006, 10:42 PM   #20
Does any one have a picture of where they made the cuts for the hose clamp? I am trying to do this and it seems that every where I want to make a cut either the high/low motor or gears are in the way. Also what size hose clamp are you running?
Thanks
rydinhigh is offline   Reply With Quote
