01-22-2010, 11:40 PM | #1 |
Quarry Creeper Join Date: Nov 2009 Location: Hibbing
| hr dig?
i have a HR dig attached to a axial trans, issue i think im having is it seems stiff to go into different positions. I can spin big spur gear by hand easy, but it seems like it either is hard to go in to one of three positions or takes a while (spinning the spur gear) to engage to next one. i took dig apart all moves freely and such. any ideas? I hate to hook it up and burn up servos
01-23-2010, 12:06 AM | #2 |
How clean is it, and did you put any lube on it when you put it back together? You might need to just a little bit of filing on it for it to be smooth. Here are some tips from my HR... Hot Racing Disconnect Review Hope this helps. |
01-23-2010, 12:13 AM | #3 |
it wasnt super clean but wasnt bad, i will take a look at that in morning when im more aware of what im reading. also what would u lube? and with wat kind of lube? its brand new for most part dont think its been hooked up to a servo yet
01-23-2010, 08:56 AM | #4 |
what kind of lube or grease and where would u put it? new to having a dig
01-23-2010, 01:16 PM | #5 |
This is what I use: http://www3.towerhobbies.com/cgi-bin...?&I=LXGS04&P=7 But just about anything will do, I put in on the linkage where it passes though the back of the dig, where the linkage engages the dig, and a little bit on the dig itself. |
