| | #1 |
| Newbie Join Date: Dec 2005 Location: USA
| Ive had my nylint for about a month now but just found an old walmart rc car with a silverado body.. im getting ready to paint it tomorrow thats why its sanded down/taped off. Im trying to make a replica of my truck. Only real bad difference is mine is fleetside this is stepside. Mods: Extended front and back 1" Taken out springs Tummy Tuck Cut/reversed tires Rear shocks slightly inset, front inset quite far. To come: Paint Bigger Tires Grill Guard ill post more as i go. Here it is as of so far. ![]() ![]() Wheels I am going to put on Grill GuardTell me what you think.. And if anyone has any idea how to convert it to fleetside.. besides bondo (already thought of it) plz feel free to input. Brett |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Sep 2005 Location: ...Here & There
| I have the same toy but it has a Dodge body. If you get those tires & rims to fit please let us know how. Thanks in advance. |
| | #3 |
| Yeah I will... I plan on using tubing and just a series of threading and whatnot for screws and stuff.. But when i get around to that in about a week or so i will.. for now i forgot the flex pics. I am waitin for 4 new shocks with full springs cuz as you can tell clearance will definately be an issue with the tires. ![]() ![]() Major clearance issue in the back And in front as well.Brett |
| | #4 |
| Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| Where did you find the stepside silverado body at? I've been looking all over for one! A buddy of mine has one, and wants me to build a crawler replica... -WRM |
| | #5 |
| Well I just turned 16... I moved to SC when I was 10. And my parents bought that for me when we lived in Ohio.. So i probably got it when I was like 8 or 9.. I just found it in my closet.. If youre lucky you might be able to find some on ebay. But they are really old.. I think Nikko? made them. -Update- Well I figured out how to mount both front and back tires. For front i just took a allen wrench same size as the stock wheel mount, heated it up for about 5 min and then stuck it in about the needed depth. Then put a screw long enough through it, needs to be about an inch and a half long. For the back I have some small tubing, and im going to thread the inner 4-40, keep the stock wheel peg on there, do the same as the front with the allen wrench. Ill thread the rod on, slide the wheel on, cut the rod about 1/4" past the wheel, and thread the outside of the rod so I can put a nut on it. I tried to upload pics but somethin is wrong with my putfile. Ill do that later, gotta go to hardware store and walmart for paint, screws and nuts. Then I have to find my tapping set. Ill post pictures of paint progress and if i get the wheels mounted tonight. Brett |
| | #6 |
| Ultimate RC Decals ![]() Join Date: Aug 2005 Location: San Antonio
| | #7 |
| Cool bowtie.. I had been looking at your build for a while.. I even made those rock guards for my jeep and i am going to put them on my chevy. WRMorrison.. If you can find a fleetside chevy I will trade you this stepside. I have polished it, and as you can tell sanded the big areas. So its pretty much ready for paint.. Just a thought. Brett I am currently right this second melting the last rim to put on, i still havent gotten the screws and nuts i need yet. But later im going to cut, and thread the rod, then all i have to do is thread the rod on the stock axle, slide on the wheel, and thread on the nut Last edited by spastic; 01-07-2006 at 11:47 AM. Reason: Update |
| | #8 | |
-WRM | |
| | #9 |
| Well is it regular cab or extended like the one in this thread? Brett |
| | #10 |
| Ok.. Putfile is still messed up so no pics.. But i melted all 4 wheels with the allen wrench method. Then I bought the correct length screws (6-32, 1 1/2" flathead I believe) and just forcefully ^ Black peg | ^Thread| ^3/16" tubing with inner threaded 4-40 and outer end 8-32. Hard to understand but all you do is take normal setup, tap the inner part of the tubing for 4-40 and thread that onto the stock axle threads. Then thread the outer for 8-32 or 10-24 whatever you prefer and slide the wheel over the rod so the melted hex sets on the stock hex peg, and you put your 8-32 or 10-24 nut on tight and youre good to go. I know i wish putfile was working.. Ill post as soon as i can. Brett I tried to illustrate but it didnt work.. Btw WRMorrison.. go to www.newbright.com and look at their 1:20 scale remote control and you will see a ford f150 and a newer version of my silverado but same stepside body.. So they still makin them 8 years later Last edited by spastic; 01-07-2006 at 04:36 PM. Reason: Messed up |
| | #11 |
| Ok... I lied in that last post.. The inner is actually 4-48.. Hard to find so im just going to drill it big enough and epoxy it.. And the 3/16 is too big so im going to thread it 10-24 but the tubing is chromoly and its really hard and its not easy to get started.. but im workin on that now.. back wheels are a pain. Brett |
| | #12 |
| Ok.. Chromolly will not thread with the dye i have.. It appears to be dull.. So as of right now my idea for the rear wheels is a failure unless i get some softer tubing... So I have 2 front big wheels and im going to wheel with 2 small rears tonight Brett |
| | #13 |
| Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
| i wouldn't do that....gear ratios are completely different now, could destroy the axles. |
| | #14 |
| Even though i have another one for parts.. Good idea.. Well still didnt get the rears mounted but figured i would just do some poser pics.. One thing i dont like.. the backspacing the front is ALOT different that rear.. So the rear are alot farther in than the front.. Well heres the pics. http://img459.imageshack.us/my.php?i...scn18930nz.jpg http://img461.imageshack.us/my.php?i...scn18943pi.jpg http://img461.imageshack.us/my.php?i...scn18959ip.jpg http://img461.imageshack.us/my.php?i...scn18961im.jpg Screw putfile Brett |
| | #15 |
| So, what's the WB on your 1/20 silverado? The one I had was the same as in the link (extended cab, same color, etc.), I believe that it was a new bright as well. -WRM |
| | #16 |
| You asking from fenderwell to fenderwell? Or axle to axle? Brett |
| | #17 |
| Axle-to-axle. -WRM |
| | #18 |
| 10.5" Brett |
| | #19 |
| Alright... Gave up on the tubing idea.. And just glued the stock rims to the inside of my other rims.. I have it all put together and what not.. I have to clean up my mess and then ill post pics. WRMorrison.. Since thats an extended cab you could get your hands on im just gonna keep this body.. Im going to prime it in the morning, sand it and later paint it. Should have pics tomorrow night. Brett |
| | #20 |
| Thread Tools | |
| Display Modes | |
