01-10-2006, 02:48 PM | #1 |
Rock Stacker Join Date: Oct 2005 Location: Montréal!
| e-maxx tranny help what is the biggest spur for an e-maxx? wel biggest spur with 32 pitch. and do you have to use the slipper clutch on the e-maxx because i'm building the tranny and ordering it par by part because you cant get it in one peice and if I dont need to put the slipper in i wont because i would of locked it anyways. |
01-10-2006, 02:55 PM | #2 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
76 is the biggest, but everyone mostly runs 72... yes you can buy it in a whole from someone on RCC. it would be cheaper anyway. and no you don't need a slipper smallest pinion is an 8t pinion Last edited by TwistedCreations; 01-10-2006 at 03:01 PM. |
01-10-2006, 02:57 PM | #3 |
Pebble Pounder Join Date: Dec 2005 Location: Yorkshire, UK.
biggest spur gear for the e tranny is 72 teeth, with smallest pinion of 9 tooth.
01-10-2006, 03:01 PM | #4 |
with 72 spur, 9 pinion and stock motor plate do i need to make kind of a custom mount or i'll be able to get the meshing right. your sure about the slipper? (thanks for answers btw) |
01-10-2006, 03:03 PM | #5 |
yes you can mesh it right and UMM no I'm not sure of the slipper. I have never built an Emaxx before but you would need the flat pieces that go on both sides of the spur though.. no need for the sping crap though |
01-10-2006, 03:09 PM | #6 |
yes but that is the slipper assembly w/o the spring |
01-10-2006, 03:14 PM | #7 |
ok and does 76/9 works w/o "machining" because I'll put a servo for 1st and 2nd speed so i want alot of torque and if i need wheel speed i'll just shift in 2nd. |
01-10-2006, 03:35 PM | #8 |
76 and 9 will mesh i think in the standard mount. If not its simple to mesh it properly. On the mount where the adjustable screw hole is, this can be made longer towards the outer side by drilling it. |
01-10-2006, 03:49 PM | #9 |
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
9/72 or 9/76 will mesh with no mods. I run the 9/72 with a 55t lathe, it works good on my TxT hybrid.
01-10-2006, 03:57 PM | #10 |
thanks alot can i have part number for the 76 one plz and what about the slipper assembly do i have to order it? or it will work w/o? |
01-10-2006, 05:00 PM | #11 |
The slipper eliminator also works with the Maxx tranny.
01-10-2006, 05:27 PM | #12 |
i dont know that slipper iliminator? and do i need it? |
01-10-2006, 07:59 PM | #13 |
Quarry Creeper Join Date: Feb 2004 Location: Mobile AL
the 76 tooth spur is robinson racing part number and you need the entire RRP slipper assembly, 72 is a traxxas... go to RRP's website and look at Maxx slipper conversions... Later, Jake |
01-10-2006, 08:23 PM | #14 |
perfect now lets hope my lhs can get rrp products.
01-11-2006, 11:12 AM | #15 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
01-11-2006, 05:49 PM | #16 | |
