01-11-2006, 09:01 AM | #1 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
| pinion gear
i have my clod crawler almost complete but am wondering if the pinion doesn't fully touch the plastic gear if it will cause problems. i am running 9t pinions on 55t motors and have already put rcguy adjustable motor mounts on. the pinion is basically at the tip of the motor arm and i can't extend it futher so that the entire pinion's teeth come in contact with the plastic gear inside. anyone got any ideas
01-11-2006, 10:13 AM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: Yorkshire, UK.
which way is your pinion? If you put the grub screw to the inside of the motor shaft u can hang the pinion over the edge and still just screw it on. |
01-11-2006, 10:21 AM | #3 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
The RCGUY 8 tooth pinions contact the full face of the input gear.
01-11-2006, 11:03 AM | #4 | |
Rock Stacker Join Date: May 2004 Location: Idaho
01-11-2006, 02:16 PM | #5 |
i figured that i would soon strip gears or it wouldn't be as efficient. thanks
