01-16-2006, 08:01 PM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: Lindon
| Broken front axle
I was wheelin' tonight and broke my front axle coupling. I have 2.2s and I have done the low gear mod so something was bound to break. I was just wondering if any of you have had the same problem and what you did to fix it. I am going to try fixing it tomorrow, but I wanted to get some ideas before I started.
01-16-2006, 08:18 PM | #2 |
Quarry Creeper Join Date: Aug 2005 Location: crescent city
can you weld the 2 sides together & jb weld the gears in place??
01-16-2006, 10:08 PM | #3 |
The gears can't be glued together because they need to move independently. I was thinking about jbing something I just don't know what yet. I need to look at it some more and see what I have laying around the house. But your input is greatly appreciated.
01-16-2006, 11:34 PM | #4 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
lock it in low and the gears can be JB welded to the black piece....after than i have no clue, just throwing a little input in
01-17-2006, 06:25 AM | #5 |
they dont need to move if you only use low gear//if you j,b,ed it you could remove the switch while you were at it.
01-17-2006, 07:23 AM | #6 |
Newbie Join Date: Jan 2006 Location: Ocean county
make a new one out of aluminum or a piece of keystock. heck any metal will hold up better.
01-17-2006, 07:56 AM | #7 |
Thanks forr the help. I will probably try a piece of key stock. I know that I can lock it in low, but since I have done the low gear mod I like to be able to switch gears. I know that I might have to sacrifice my high gear to fix this. I'll try some stuff and let you guys know. Thanks for all the input, keep it coming though.
01-17-2006, 09:31 AM | #8 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
Don't sacrifice that high gear yet, I think I have your solution. I need to run to hobby shop for parts I'll see if they have what you need, I'll post it when I get back.
01-17-2006, 10:17 AM | #9 |
Rock Stacker Join Date: Jan 2005 Location: scottsdale
yeah same thing happened to me also. i was gonna jb it andsay screw high gear. on top of the fact sunrise is sending me a new ruck cuz of it I am also gonna fix it. I'll wait for home boys response to see what he does.
01-17-2006, 03:20 PM | #10 |
Ok,here it is simple enough. I found 1/4 brass square tubing at the HS in the metal section(I have seen these "metal stations" at local hardware store also) it fits perfectly in the nylint gear selector. I sanded white plastic square evenly on all sides untill it fit perfectly inside brass. Cut brass same length and done. So basically I "sleeved" the part you broke. I'm sure you can use your broken one since it will be contained by the brass just make sure its a tight fit. |
01-17-2006, 03:33 PM | #11 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
sweet little fix... thanks for the info. |
01-17-2006, 03:59 PM | #12 |
That is genius I'm going to rin to the HS right now. This forum is great, you guys always come up with good ideas. Thanks.
01-17-2006, 04:05 PM | #13 |
by the time i decide to pick up a 1:18 to go with my 1:6, people will have come up with enough mods to make these things completely bombproof.
01-17-2006, 05:53 PM | #14 |
Newbie Join Date: Nov 2005 Location: oxnard (so cal)
i also had the same problem of course on a weekend wayy to late to goto any hw store so i used ca glue or super glue whatever your choice is then i used a set of pliers to hold it together while it dried......so far no problems. works great if your in a pinch.
01-17-2006, 06:08 PM | #15 |
I think this needs to go in the mods section. I would do it but I don't know how.
01-17-2006, 08:09 PM | #16 |
Rock Stacker Join Date: Dec 2005 Location: Lowry City, MO
thats a sweet idea, but do you have to do any sanding in the black drum for the brass tube to fit in it?? my nylint is now locked in low cuz i had to use some super glue, now i cant chase my cat anymore, lol NVM NVM... sorry for that, i just didnt read the threads good enough, sorry fer the inconvenice |
01-17-2006, 09:15 PM | #17 |
I didn't have to sand the black drum at all. The square tubing fit in there perfect. You do have to sand the white piece though.
