01-19-2006, 05:53 PM | #1 |
Rock Stacker Join Date: Jan 2006 Location: Marysville
| couple of problems
i am having problems with 2 things on my crawler one of them is when i let go of the trigger in drive the crawler still runs on its own, the other is what the hell is the popping in the front diff when my front tires hook up and try to pull? any tips on fixing these problems one other thing is a axel flip a extremely good idea?
01-27-2006, 01:44 PM | #2 |
can anyone plz give the the answers? |
01-27-2006, 02:00 PM | #3 |
Newbie Join Date: Dec 2005 Location: USA
Search But most likely... crappy stock electronics... your gears slipping (metal one slipping on a plastic one) theres a thread already in this forum about that. And if you wanna do an axle flip then do it.. it cant hurt. Brett |
01-27-2006, 09:43 PM | #4 |
Quarry Creeper Join Date: Jan 2006 Location: Dallas
first have you tried a different band? mine did that and i just switched bands, and it worked fine. And second you might check the multiple sets of planetary gears in the gearbox. there might be a gear out of place.
01-28-2006, 05:30 PM | #5 |
well the band thing dont work so i will go will crapy electronics and the gear thing i will give a try thanks alot
