01-21-2006, 02:17 PM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: Yorkshire, UK.
| I found a mag mayhem!!
I went to my LHS today to get a gear reduction box and while waiting at the counter i peered in to the glass cabinet crammed with motors. What did i see... a mag mayhem! The lady said she was cleaning the cabinet and the motor had fallen down the back out of site of anybody! I was well chuffed. Even tho i just spent 30 notes on a new motor i had to have the mag mayhem. I also got a 2.9:1 reduction box and i was wondering... It came with a 13 tooth pinion to put on the motor and was wondering if i put 9 tooth pinion on what would the ratio be then? The reduction gear has 38 teeth if that helps! Help is apreciated, thanks. |
01-22-2006, 12:42 AM | #2 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
Well as you said, the stock ratio is 2.9:1. You get that number by dividing 38 by 13. So, if you are swapping a nine tooth pinion, you would take 38 divided by 9, giving you a 4.2:1 reduction. Just be sure to check if you can maintian a proper mesh when you use the 9 tooth pinion. Good score on the MM, by the way.
01-22-2006, 05:54 AM | #3 |
thanks a lot, ill probly buy a few different pinions and then figure out which is best from there!
01-22-2006, 08:14 AM | #4 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Your Brownie Button is in the mail.
01-22-2006, 08:40 AM | #5 |
can i have two please?
01-23-2006, 08:31 PM | #6 |
I picked up a nos Kyosho 360ST just the other day...I had one of those back when they first came out....torque monster! I have wanted a new one for several years and a friend had one that he didn't want!
