Thread: steering
Old 01-21-2006, 04:56 PM   #1
Default steering
hey guys was wondering if anyone could help me out...maybe even a thread on how to convert to a servo steering set up or something...my steering is stuck to the right and if i turn everything on it doesnt come back i turn the steering on the remote and it doesnt make a noise or anything theres no burnt wires that i can see...someone please help i havnt wheeled this or the full size jeep yet (thats a project) so i wanna mess around with this again
thanks alot
paul
PRBJeepin is offline   Reply With Quote
Old 01-21-2006, 05:56 PM   #2
First I would make sure your battery is fully charged, and the 9V is good also. Then try all 4 different channels and see if it lets you control it. Might be something interfering with the channel you are on. I know if you run two of these on the same channel in close proximity, something like you just described will happen.
mudking82 is offline   Reply With Quote
Old 01-21-2006, 06:26 PM   #3
battery is full charge...i tryed the different channels. i didnt check the 9v in the remote but it does go forward and reverse.
Old 01-21-2006, 08:22 PM   #4
Put the front end up on a block, turn on the jeep and your controller, and then turn the little knob on the controller labeled "steering trim". What happens?
Old 01-21-2006, 08:31 PM   #5
nothing...doesnt even make a noise like its trying..i took it apart and that little switch for left and right wire colors (red, black, white?) if i turn that the steering works only one way if i turn it the other way it does nothing...is there anyway i could get rid of this and wire in a servo or something
Old 01-22-2006, 12:55 AM   #6
You can't really put hobby servos on these things, the electronics aren't compatible.
gregman_1 is offline   Reply With Quote
Old 01-22-2006, 09:04 AM   #7
well that kinda sucks...anyone else got ideas on how to fix this thing
Old 01-22-2006, 10:01 AM   #8
hey guys i was just looking through the 1:18 some guy is swaping the elc. could i do the same and use the remote and recever from my 10th in one of these??
Old 01-22-2006, 11:24 AM   #9
yes, if you were to install a hobby grade ESC, reciever, remote, and servo, you could....
i am not sure how well the motors would respond to the lower voltage (not very well i would assume) so you would need to look for an ESC and possibly a servo that will run on 12 volts
SlammedMini469 is offline   Reply With Quote
Old 01-22-2006, 01:47 PM   #10
ahh this is a pain....i guess ill just buy a new one and use this one for parts or something...or maybe ill see if someone on here has parts they wanna sell
Old 01-22-2006, 05:47 PM   #11
take it back to walmart they will exchange it no problem. If you have modified the body just buy a new rig and change bodies out and then take the old chassis with the new body back to exchange it they will give you your money back. I have done this twice already.
FroggF350 is offline   Reply With Quote
Old 01-22-2006, 07:55 PM   #12
Frogg, did you not see the sticker that says DO NOT RETURN TO STORE?
Nylint has excellent customer service
Old 01-22-2006, 09:22 PM   #13
yea um i thought about this...first i tummy tucked it. 2 theres no walmart around here that sells the 1:6 scale i got mine in pa and left the box there. i would much rather just fix it
