01-23-2006, 08:43 AM | #1 |
Rock Stacker Join Date: May 2004 Location: Idaho
| arrow shaft links
I setup a set of arrow shafts for links..... I would like to run the shocks to the links what is the best way to make this happen. I thought of using couplers(sp?) but thought the set screw would damage the arrow shaft ...any help
01-23-2006, 08:49 AM | #2 |
Pebble Pounder Join Date: Oct 2005 Location: I need MORE GIGGLE JUICE
Cable clamps, plastic or if you can find them metal. A small piece of shrink tubing over the shaft well keep them from slipping.
01-23-2006, 08:58 AM | #3 |
thanks for the fast reply ..I think I need somthing more solid though I dont want the shock to rotate on the link...any other ideas
01-23-2006, 01:10 PM | #5 |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
as long as the cable clamp is tight on your link it wouldn't rotate because use them on my clod and ran about 20 packs thrue it.
01-23-2006, 03:58 PM | #6 |
Built, not bought Join Date: Oct 2004 Location: Gresham
| WWW.CLODMODRACING.COM has shock mounts for 1/4 inch or 5/16th.Either way they will still rotate unless you have your link ends screwed tight against the shafts.
