08-05-2011, 07:23 PM | #61 |
Newbie Join Date: Jan 2011 Location: reno
stock 1st round mods the receiver took some beating there so i changed some chit then broke both axle housings, a few weeks apart swapped in complete axial units including guts put this body on doing stupid chit to find the weak spots trimmed body, added larger pinion, changed link positions, installed cage |
01-14-2012, 02:11 PM | #62 |
Newbie Join Date: Jan 2012 Location: WHITTIER
| Re: exceed maxstone 10
what springs are you guys replacing the stock springs with ? anyone have any feed back on the Ckrc stage one kit and if it corrects the torque twist ?
01-14-2012, 02:54 PM | #63 |
Quarry Creeper Join Date: Oct 2010 Location: Paragould
I never replace my springs never needed too That won't stop TT do seArch on TT it is link placement for the most part He'll I still run stock springs/shocks on my comp MOA now |
01-14-2012, 03:42 PM | #64 |
| Re: exceed maxstone 10 Is there a ideal place on the maxstone to place the links to correct TT or is it trial and error
01-14-2012, 03:48 PM | #65 | |
Newbie Join Date: May 2010 Location: raleigh
| Re: exceed maxstone 10 Quote:
i got the stage 1 kit, it helps, but there's still noticeable TT. sucks, but i've learned to live with it. i tried putting pen springs inside the shocks, that didnt help either. | |
01-16-2012, 01:10 AM | #66 |
Newbie Join Date: Jan 2011 Location: bay area
Mine came with 3 sets of springs. I used the stiffest ones on the rear, moved rear lower links to the inside of the chassis, and there is no torque twist.
01-16-2012, 07:40 AM | #67 |
mind tossing up some pics spiff? i've moved my links around too, but i've still got TT
01-17-2012, 06:19 PM | #68 |
Quarry Creeper Join Date: Sep 2010 Location: Berlin, VT
Can you just flip the motor around so the weight of the motor is on the passenger side of the crawler? Youll still have TT going in reverse, but shouldant be there going forward. Worked on my 16.
01-21-2012, 12:35 AM | #69 |
Sorry no pics at the moment. Pretty simple, unbolt the links and move them inside. Might need longer bolts and grind the trans mount. I forget, it's been a while. And only the rear fits since the motor is in the way. I think I got the idea from a search I did on this site.
01-21-2012, 12:41 PM | #70 |
I odered my maxstone the other day. I did enough reading and am inboarding the lowers,moving them out on the houshing side. Building a battery tray,and upper D mount
09-08-2013, 12:33 PM | #71 |
Newbie Join Date: Jun 2013 Location: orlando
My girlfriend bought a 1/10 scale maxstone crawler in march of 2013, It worked good the first 3 times using it around the complex I live in. There is a variety of terrain to go wheeling on, some rocks, embankments and so forth. The fourth time crawling up an embankment the rear axle quit pulling,I took the differential apart and the plastic connect box the axles connect to stripped out. Since no replacement parts were available on nitrorcx on the site, my girl called them directly, they found one connect box in their inventory and she bought it. I installed the new part and ran the toy, the front connect box stripped out on that outing, since no other parts are available i J B welded the axles to the connect box . It is only a patch, the weld breaks after running a couple of times. I do bnot recommend this crawler for any hard four wheeling. I run an HPI Crawler King that has been indestructible. I even built a trailer it pulls to haul the max stone since it breaks alot
09-08-2013, 12:46 PM | #72 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
The kid and his buddy have had one for over a year and they kick the crap out of it and the lockers are still fine in theirs.
09-08-2013, 04:31 PM | #73 |
Rock Stacker Join Date: Jul 2013 Location: Parker
I have a 1/8 th scale dodge body on mine and some Pitbull rock beast tires, my daughter and I use it as a trail basher, 6 months and its still hanging in there, I think a Axial wraith will be next, cheers
12-18-2013, 09:47 PM | #74 |
Newbie Join Date: Oct 2013 Location: Ecuador
I want to put a dig unit on my maxstone 10, currently my upgrades are: - front steering with a savox 1256 - rear steering with stock servo (sucks as it cannot handle weight of the rc) - alluminum gears from helipal (hsp pangolin = exceed maxstone) - 150g weight for front wheels I've been reading about those dig units for single motor applications, but none of them are designed for maxstones, so I'd like to know if anyone has ever tried to put those dig units |
12-18-2013, 10:13 PM | #75 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Heres my Exceed maxstone Custom carbon fiber chassis Axial ESC ,radio and receiver. proline Titus wheels with Panther T485 tires Axial 90mm RTR shocks Axial 27T RTR motor (for now) 14T motor pinion/ 87T spur Powered with a GensAce 4000mah 2s lipo Stock axles,driveshaft and trans. Last edited by 6sharky9; 12-18-2013 at 10:25 PM. |
12-22-2013, 08:02 AM | #76 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
How similar is that trans to an ax10? That chassis setup looks great! I think a set of 1.9, and a 1" drop in the skid height would make it look killer! |
01-12-2014, 12:08 PM | #77 |
Newbie Join Date: Jan 2014 Location: Orion
Will the complete diffs/ axles drop in ? So take one off of a axial and by it up to the exceed ? An yeah what about the trans ???
01-12-2014, 03:59 PM | #78 |
Newbie Join Date: Jul 2010 Location: Bend
You could also grind off the diff guard mounting posts on the bottom of the pumpkin but grind too close and you might go all the way through. I did this to mine and just put some epoxy over the holes and ground that down. No more catching on the rocks though. Those posts MAY be hollow, that might be why I went and made a hole. You can get epoxy in a tube that's ready to go with hardner and all at the auto parts store. Just pinch off a piece, kneed it like dough and that activates all the chemicals and makes it more plyable. Drys hard as a rock. Good stuff to have around.
01-26-2014, 09:22 PM | #79 |
Rock Stacker Join Date: Jan 2012 Location: Columbia, MO
I just ran my first full pack through my max 10 today. Quite impressed really, for the price. I didn't realize it came with waterproof electronics but started looking as I was making a few mods and sure enough it is waterproof. I did switch to lipo 2S, rover tires, cut trans mount and I boarded links, batt on front links all electronics on top plate but upside down and underneath. Cut body (a lot) and lowered front with stock axial shocks. Sure did get rid of those rock catching axle guards and smoothed the mounts. I did not like the steering at all, servo has no power and doesn't turn near enough to suit me. Seems like some bent links are in order as well. Again, for the money seems like a great platform.
03-07-2014, 12:42 PM | #80 |
Rock Stacker Join Date: Feb 2014 Location: Irmo, SC
Anybody still running this truck? I want to make mine a little more scale. I don't mind sacrificing crawling ability. I have seen some videos of a Silverado body that looks good on it, but every time someone asks what body is that the guy never answers that question. What wlil fit with the stock wheelbase? I also might use some C-channel to mount real bumpers on it. I'm thinking a silver and lime green paint job would look good with the green anodized parts.
