01-25-2006, 05:57 PM | #1 |
Newbie Join Date: Dec 2005 Location: Kansas
| You guys doing upgraded electronics
How you doing it? I'm pretty green when it comes to electronics....volts, amps, resisters.....yadda-yadda-yadda. For us common beer drinking folks (Shlitz and below), can you give us a walk-through? I'm talking keep-it-simple kind of stuff. I'm dieing to upgrade me electronics, but don't know how to make the battery power the boards power the motors and SERVO I'm wanting. Thanks.
01-25-2006, 07:41 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
are you talkin hobby grade electronics or designing/building your own? most of the hobby grade stuff is pretty simple (just read the directions and plug everything where it goes) i use a electronic speed control (ESC), reciever, radio, and a 7.2V NiMH battery. i bought them all from tower hobbies |
01-26-2006, 04:57 AM | #3 |
OK, that sounds pretty simple. I'll do some pokin around on Tower and see what I can dig up. Thanks.
01-26-2006, 03:43 PM | #4 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
does the nylint have standard servo plug and voltage requirements?
01-26-2006, 10:43 PM | #5 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
none of your stock electronics will be reusable (except the motors) you will also have to lock it in low. you will need a radio and reciever (i would recommend a 3 channel, in case you ever want to install a winch or anything... www.thecrawlerstore.com has a nice 3 channel setup that is fairly cheap), a servo (high torque), an ESC, and a new battery (not many ESC's will handle 12 volts, and the ones that will aren't cheap. |
01-28-2006, 07:03 PM | #6 |
I would like a way to use the stock steering servo set-up with a standard esc, is that possible? does the stock one run on 12 volts?
01-28-2006, 07:06 PM | #7 |
its not possible to use the stock steering setup with habby grade electronics. the Mylint uses a motor (like the ones in the axles) and it operates the same way, the polarity is switched in order for the motor to change directions. thereofre there are only 2 wires going to the motor. in hobby grade servos, 3 wires go to the servo....positive, negative, and signal...... |
01-29-2006, 07:52 AM | #8 |
Thanks :neutral: |
