04-22-2010, 02:00 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: Floyds Knobs, IN
| transfer case question? http://www.rc4wdshop.com/go/product_...roducts_id=314 what does this do? if im correct it allows the switch from FWD to RWD to 4WD.
04-22-2010, 02:13 PM | #2 |
RCC Addict Join Date: Dec 2005 Location: Tucson
Its 1.1 ratio it does nothing, its just for looks mostly
04-22-2010, 02:16 PM | #3 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
Not for looks. It allows you to run a t-case in the middle of your rig, where your tranny normally would be. Then the tranny and motor can be moved up front under the hood and out of the way, just like a 1:1. Used all the time in the scale world. The t-case is much smaller and can usually fit underneath the interior of the cab which is why it's used.
04-22-2010, 02:19 PM | #4 |
sound like for looks to me. They making it look like a atlas without any function. that would be for LOOK'S
04-26-2010, 05:06 AM | #5 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
If it served no function then I doubt it would appear in so many builds... Its just as ecoli said, it allows a trans with a big flywheel to be mounted up front, and then the power is sent to the much smaller t-case, then forward and back to the axles from said much smaller t-case that can be hidden under an interior. And adds an element of scaleness if thats a word. Motor--trans--transfer case, as in a 1:1... engine--trans--transfer case
04-26-2010, 05:17 AM | #6 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
if your building something with an open interior a transfer case is almost always needed. |
04-29-2010, 09:28 AM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
04-29-2010, 09:35 AM | #8 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Yes its for looks, its also functional. Depends on what your using it for. Will it switch between 4wd and 2wd... no. does it make it possible to run a full interior...yep |
