02-01-2006, 09:12 PM | #1 |
Pebble Pounder Join Date: Sep 2005 Location: Auburn
| Winch
Has anyone tried the whole winch thing any other way than taking a 1/18th axle?? It's jsut so big. I was thinking about a sailboat winch, but can't find any online anywhere
02-02-2006, 12:25 PM | #2 | |
Quarry Creeper Join Date: Jan 2006 Location: knoxville
02-02-2006, 12:27 PM | #3 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
Try searching outside of the Nylint forums, it's amazing what you will find. http://rccrawler.com/winch.htm |
02-02-2006, 02:47 PM | #4 |
Already saw that badger..thanks, but i want something different...smaller...
02-02-2006, 04:27 PM | #5 |
I joined the Band! Join Date: Dec 2005 Location: portland
you could use a motor out of one of these http://images.search.yahoo.com/searc...tt=35&ei=UTF-8 |
02-02-2006, 04:35 PM | #6 |
Rock Stacker Join Date: Jan 2006 Location: On the rocks...
Use a micro servo. There are MANY sizes of servo available, one of them should do what you want. Last edited by vlmarshall; 02-02-2006 at 04:40 PM. |
02-02-2006, 07:35 PM | #7 |
my buddy actually has one of those, and before he got his 1:6th, he tried to tell me that thing was going to out-do the nylint...FAT CHANCE....anyway....the servo above looks good, I apperciate it! THanks for the help!
02-02-2006, 08:03 PM | #8 | |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
02-02-2006, 08:31 PM | #9 |
well then...when are you builing me one?
02-02-2006, 10:08 PM | #10 | |
If your truck can't make it up a SERIOUS rockwall, find a good anchor and start running cable. A winch can make the difference between climbing, and falling over on your head, but there's no sense in making it do ALL the work, when you have two more HUGE motors and gear reductions in those axles. | |
02-02-2006, 11:19 PM | #11 |
exactly, you have it, its just a helpin hand in a sitchyation
02-03-2006, 06:55 PM | #12 |
RCC Addict Join Date: Sep 2005 Location: Lehi
In the Tech. page, there is a Step-by-Step way to build a winch from a servo....Unless you have already checked it out:-P
02-03-2006, 08:05 PM | #13 |
I saw that, was jsut wonderiong if anyone ha gone about it in a different way...
02-04-2006, 08:28 PM | #14 |
Pebble Pounder Join Date: Dec 2005 Location: West ky, Benton
| i use the 1/18 method and with it in low gear using a 7.2 volt pack to run the winch this thing will pick my 1/6 off the ground and i have soem funny video of my new E-maxx getin pulled over a rock pile that it couldnt climb by my 150$ wally cralwer. but anyways the 1/18 rear axel is a very effective winch! |
02-05-2006, 10:23 AM | #15 |
where are you mounting the big dang axle?? That's my only problem with that route...
02-05-2006, 10:27 AM | #16 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
I got a working stock gear reduction/motor for a nylint front axle..
02-05-2006, 04:22 PM | #17 |
mount it up front under the front over hang where ur body catches drill a hole and mount it there trim a little on the front axel and ur done i even used the antanna from the 1/18 and made a small hole for it to come thought the body of the jeep like a radio antanna! um i could send some pics, pm me ur e-amil ill do it monday afternoon:-P |
