Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: 1/6th Wheel Adapters!!!
Old 02-04-2006, 01:24 AM   #1
Default 1/6th Wheel Adapters!!!
OK this is not another thread asking if any one has made them or how they get other rims to fit on the 1/6 nylint. This is a thread showing you that I am SMRT I got a fire under my a$$ and thought of a way to make some. So that is what I am here to show you. That there is a way to get any 12mm rim to fit on your nylint.
I am in the process of making some for any 14mm rim also.
Alan
Mr. Chevy is offline   Reply With Quote
Old 02-04-2006, 02:41 AM   #2
Post
wow thats smart
i knew you was smrt!!
adawg69 is offline   Reply With Quote
Old 02-04-2006, 08:16 AM   #3
Wow, only two days too late
Someone say DIY Wheel adapters?
Mutt is offline   Reply With Quote
Old 02-04-2006, 09:25 AM   #4
See the only thing about that thread is that it doesn't show you pics of the ones he made. So I am just showing you how I made some
Old 02-04-2006, 10:05 AM   #5
And if you read the thread its because I had to go to bed and then get up and go to work.
Yours look to be a small conical nut welded to a 10mm socket?
I'm going to finish mine today, slept ALL day yesterday when i got home so getting these adapters done and turning rear axle parts into front axle parts are my only goal today.
Old 02-04-2006, 10:59 AM   #6
How are the adapters supposed to stay on the Nylint stub axles??
RANOVRU is offline   Reply With Quote
Old 02-04-2006, 12:10 PM   #7
Default lol
woot some one has made adaptors i thought i was gonna be the only 1 running different thab stock on my 1/6 for the longest time... guess not lol took u guys awhile tho
fyi running bigger/wider tires strips ur gears just so u know before u go make/buy adaptors happened to mine with 40s moabs
Face The Karma is offline   Reply With Quote
