Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Suspension
Old 02-04-2006, 12:41 PM   #1
Default Suspension
I was trying to find the best way to put my suspension i know that 4-link is the best but i was trying to see if there was a other way i know about a 3 link to but i would like to get some pics and see wut every one has and the price and how they did it and i would like to know wut is the best way to get the most out of the stock shocks i cut 3 coil and heated them up so they r softer but it does not flex as good as i want and would like to know if any one has a 1:6 scale that they r selling write back
Jeeps For Life
ComancheCrawler13 is offline   Reply With Quote
Old 02-04-2006, 10:41 PM   #2
Mayor of Bedrock
freetimecrawler's Avatar
www.walmart.com $119.99 on clearance 1:6 Jeeps
freetimecrawler is offline   Reply With Quote
Old 02-05-2006, 12:04 PM   #3
if you want ultimate flex with out buying anything, go inboard shocks front and rear. all you have to do is make up a bracket for the back so that the shocks are parrallel, then bolt your shocks into the bracket, for the front, one shock mounts on the back of the stearing motor box (take motor out before drilling) and you need a bracket for the other side, you'll also need about a half inch lengthenin front and rear
Bknight is offline   Reply With Quote
Old 02-05-2006, 05:50 PM   #4
Speaking of the 3 link. How is it done? I can't really go to the LHS to buy more links so I'm trying to work with what I've got. pics?
Collapse_The_Masses is offline   Reply With Quote
