| | #1 |
| Newbie Join Date: Apr 2005 Location: Madison, WI
| I got the traxxas plastic sliders and plastic yokes and i'm having some problems... is there an easy way to install the metal cross piece that connects the slider to the yoke? i broke two yokes already trying to bend the plastic with a needlenose... is there something i am missing here??? |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Sep 2005 Location: CEN-CAL
| I use the same method you tried, but I just heat them up a little so they're not so brittle. |
| | #3 |
| Newbie Join Date: Dec 2005 Location: BC Canada
| The tool that Traxxas sends with the truck kit works fine, just you need to weld a small handle to it so you can hang on to it. But it does the same as the pliers, bends the one tab up so the link snaps in. Does make them easier to soak them in hot water first for short time. |
| | #4 |
| Pebble Pounder Join Date: Jun 2005 Location: boston
| i use a big pair of channel locks and run it under the insta-hot for a few seconds |
| | #5 |
| Rock Stacker Join Date: May 2005 Location: Streetsboro
| It's very easy with the right tool & the right technique. Download this assembly manual & check out page 8: http://www.traxxas.com/products/elec...t_assy_man.pdf To make it even easier, make a yoke tool out of a screwdriver. It's ALOT easier to work with. Click here & scroll down to "Yoke Tool": http://www.swami-rc.com/tips.htm |
| | #6 | |
| Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
| Thread Tools | |
| Display Modes | |
