Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: in board front suspension
Old 02-05-2006, 10:31 AM   #1
Default in board front suspension
finally figured it out on my friends scorpion last night, it works just as well as the rear. All you have to do is put on shock on the steering box motor, and make little bracet for the other one, longer wheel base is need up front.
Bknight is offline   Reply With Quote
Old 02-05-2006, 09:03 PM   #2
got any pics??? cant quite understand what you did....
Rocker is offline   Reply With Quote
Old 02-05-2006, 11:32 PM   #3
i'll get some pics probly tomorrow if i'm not to busy, its on my buddies rig
Old 02-06-2006, 02:16 PM   #4
screw the p-side shock to the back of the steering motor box, then what i did was cut off the shock bracket for the d-side on the axle and glue it in a place corresponding in geometry to the p-side one. worked great
Click the image to open in full size. look closely
pistonbone is offline   Reply With Quote
