| | #1 |
| Newbie Join Date: Feb 2006 Location: Glastonbury
| Hey, I saw some chatter about the multiple channels interfering, but I didn't see a fix. I'm trying to run my 1:18 with my sons. We've tried all the combos, but there is always a time when one will work and the other won't. It looks like proximity has something to do with it. For instance, it's best 1) If the 2 transmitters are not tto close together and 2) The "other" crawler and transmitter don't get too close together. If that happens, the "other" crawler will stop dead. It will work again once the other transmitter isn't sending a signal. Any similar experiences? Is there a fix? Thanks in advance. |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Jan 2006 Location: Scottsdale
| Ive had the same problem, I think some transmitters might be stronger than others, my girlfriends car works all the time and mine works intermitedly.... |
| | #3 |
| Pebble Pounder Join Date: Jan 2006 Location: outside reading, pa
| i always run 2. me & kortam had interference issues when he ran 3, but no problems on 1 or 4. |
| | #4 |
| Newbie Join Date: Dec 2005 Location: Marshy Creek
| We've tried all different combinations of channels, but still cannot run 2 simultaneously . . . |
| | #5 |
| Newbie Join Date: Feb 2006 Location: Seattle
| this happened to me and a friend as well. But mine is all messed up. I need a new one, is it possible to get a new transmitter for these nylints? |
| | #6 |
| Quarry Creeper Join Date: Jan 2006 Location: Wales
| i have a spare transmitter if u want it 10$ |
| | #7 |
| Newbie Join Date: Feb 2006 Location: Columbia
| I have had the same problem.....I have 3 1:18 scale and 1-1:6 and we cannot run them at the same time.....I was soo disappointed! They are still great fun, but the kids like to race things! |
| | #8 |
| Quarry Creeper Join Date: Jan 2006 Location: Flushing, MI
| Problem is that they are all on 27.145 frequency, and the swich just plays with it from there a little bit. never really gets far enough away from 27.145 to stop problems from happening. Only cool thing I have found about the 4 channel switch is with one radio and a couple trucks, you can select the one you want to drive for more to play with. |
| | #9 |
| Pebble Pounder Join Date: Nov 2005 Location: Honolulu
| There should be a adjustment screw of some sort, most likely a potentiometer, somewhere. It will be a little square with a circle on top. If you scrape the wax out, adjust the adjustment thingy until everything is good. But thats IF theres a pot. Or just get 4 trucks, 1 controller, set them all to one chan, and go do some RC dancing! |
| Thread Tools | |
| Display Modes | |
